Lack of power?
Old Aug 31, 2012 | 03:36 PM
TL0VE's Avatar
Lack of power?
Hello i have an 08 acura tl 78k miles i just changed the tires 2 days ago and need an alignment badly. So i was wondering if thats the reason im feeling a lack of power. I dont usually notice stuff like this but it was very noticeable.
Old Aug 31, 2012 | 04:33 PM
johnfilice's Avatar
Doesn't seem like a realistic cause and effect. I would say get an alignment and see if that does anything. Try and explain what you mean by lack of power as well.
Old Aug 31, 2012 | 04:46 PM
04socalTL's Avatar
spends his lunch $ on his
was it hot? these cars are very sensitive to heat soak
Old Aug 31, 2012 | 06:29 PM
leedogg's Avatar
RAR
what battery does it have?
Old Aug 31, 2012 | 07:07 PM
Steven Bell's Avatar
TLove, I don't think so. It's hot outside still-wait until you get back into the mid-50's.
Old Aug 31, 2012 | 08:45 PM
TL0VE's Avatar
instead of feeling the acceleration it i had to force it to take off and still didnt take off fast
it was 83 degrees out today but first time it happened all summer
not sure i believe the one that came from factory with the car
it hasnt happened all summer when it was hot though and it wasn't a little difference
Old Aug 31, 2012 | 09:17 PM
Italiano's Avatar
Maybe the new tires are heavier....
Old Aug 31, 2012 | 09:18 PM
vietxquangstah's Avatar
I got 2 new tires installed and now I have a lack of power!!
wtf?
Old Aug 31, 2012 | 09:28 PM
truonghthe's Avatar
^^^^lol.
Old Aug 31, 2012 | 10:02 PM
connork53's Avatar
Try loosening the lug nuts and driving.
Old Aug 31, 2012 | 10:15 PM
Nova_brad's Avatar
No.
Old Aug 31, 2012 | 10:24 PM
DANELSON's Avatar
so true any degree above 90 my tl feels sluggish
Old Sep 1, 2012 | 02:40 AM
cinobyte's Avatar
83 degrees could cause some heat soak i guess. Mine seems a bit sluggish when it gets hot it just losses some pep. I am all about batteries lately if you have a 4 year old oem battery its probably time to get new one. I have seen many post here where a new battery gives the butt dyno +/-15 more whp. obviously that's not the case but many have mentioned noticing a difference from replacing the battery. I can guarantee changing out the tires did not cause a power loss unless you dropped some twenties on it. you may have picked up a few more pounds with new tires but you would never notice that.
Old Sep 1, 2012 | 03:46 AM
Moe5193's Avatar
i have an 07 tl-s with 60k and to be honest temperature hasnt affected my car at all i just put an XLR8 exhaust on two days ago and wanted to take a drive in 95 F weather today and no lack of power @tllove you have a stock air filter? maybe you should drop in a new one or clean your intake filter...hope it helps
Old Sep 1, 2012 | 07:00 AM
truonghthe's Avatar
OP try to reset your ECU may be that will help you with the "feeling loosing power". Searching for a thread of "setting ECU make me happy" thread there is instruction on the DIY.
Old Sep 1, 2012 | 09:17 PM
TL0VE's Avatar
well i got an alignment today and reset the euc and the car is running well but the only thing is the car still drifts to the right.. is that normal
Old Sep 1, 2012 | 09:34 PM
Red Voodoo's Avatar
Area on my XM
My car drifts to the right on all types of surfaces and banking, but I'm also lowered on springs, which has added slight imperfections to the front and rear camber that differ from left and right (there is definitely a tad more negative camber on the right). I'm not sure if this applies to you, but a friend of my was on stock suspension and experienced the same issue.
Old Sep 10, 2012 | 09:47 PM
oreX's Avatar
It could be torque steer. Well, at least thats what i'm betting on. I just got an 04 tl with 64k miles on it and noticed it pulls to the right a little at all times. Its more noticeable if you're accelerating hard. I was figuring an alignment and tire balance would fix it, but if that didnt work for you then i'm not sure what else it could be.
emailnatec
29
Sep 28, 2018 04:27 PM
Acura604
20
Aug 5, 2017 12:55 AM
spudweb
May 22, 2016 02:39 PM
knight rider
Mar 4, 2016 08:59 AM
95oRANGEcRUSH
Sep 25, 2015 12:50 PM
