What’s causing this leak?
Old Aug 26, 2012 | 06:20 PM
ChampionFiyah's Avatar
Old Aug 26, 2012 | 06:31 PM
flyromeo3's Avatar
# 3 on the list
http://www.acuraoemparts.com/delray/...All&vinsrch=no
I think we've all encountered this.
Old Aug 26, 2012 | 06:36 PM
powerflow's Avatar
Wiggy Wiggy Wiggy
A poor seal is causing the leak.
1) Replace the rubber tube.
2) Thoroughly clean the nipple on the rad.
Apply a dab of TFE sealant/lube to the nipple O.D. before squeezing the rubber tube in place.
Also, make sure your overflow tank is not over filled.
If your car is approaching 100K, I would also replace the rad cap.
Old Aug 26, 2012 | 07:05 PM
tihomirbg's Avatar
Been having this for a long time- i put a small clamp on it and it still leaks. I moght try the TFE sealant/lube and see how it works
Old Aug 26, 2012 | 07:26 PM
My car is at 65k miles now, and I know what its like to have a radiator cap go bad on you. The cap on my 99TL went bad without warning once when I was about 500 miles away from home.
I will most likely be ordering a new radiator cap along with the pipe.
So this is what I should use to seal it?
http://catalog.antiseize.com/item/th...th-ptfe/14005?
how exactly should I apply this sealer?
Old Aug 26, 2012 | 07:39 PM
powerflow's Avatar
Wiggy Wiggy Wiggy
Apply a light skim coat to the rad nipple, just too squeeze the new rubber tube in tight.
That TFE sealant looks good. I have a small tube of TFE sealant (pool supply store) left over from fixing my hot tub, and its a great product for this type of application.
Old Aug 26, 2012 | 07:57 PM
powerflow's Avatar
Wiggy Wiggy Wiggy
Also, I would inspect the overflow cap. It should vent to atmosphere. Might be good to remove and blow with compressed air. But, I've never took a close look at the 3G overflow tank cap to see if theres any easy clog point.
Old Aug 27, 2012 | 01:53 AM
MandoTL's Avatar
Your very lucky, I have the same issue but my coolant ended up spraying all over my engine bay. Only happens when I have the A/C on and I am in hot weather or going up a steep incline.
I was clueless as to where the coolant came out from the first time and second, so I guess it was this hose or the cap or even the reserve tank cap is where the source of the problem is. I hope this fixes my issue its happened twice this month a week apart. I notice it when I clean my car every weekend and clean the engine bay inside.
I usually have low coolant in the reserve tank, but luckily have extra honda coolant to fill it back up.
Old Sep 10, 2012 | 05:31 PM
I ordered a new radiator cap, tubes, coolant tank cap, and sealant. I don't have any more leaks, but for some reason my new coolant tank cap doesn't screw down all the way, is this supposed to be like this?
Old Sep 11, 2012 | 10:46 AM
lilsid112's Avatar
I ended up putting a zip tie on both ends and no more leaks.
Old Sep 11, 2012 | 01:17 PM
TheLowLife's Avatar
^ quick and free (mostly) did the same
Old Sep 11, 2012 | 01:44 PM
SharksBreath's Avatar
BANNED
Originally Posted by powerflow
nipple, lube, squeezing
anyone else go from six to midnight after reading this thread?
Mike734
Dec 10, 2021 01:25 PM
Avenger411
Oct 11, 2015 03:53 PM
steve
Sep 30, 2015 09:23 PM
Boraxo
1/2G MDX (2001-2013)
Sep 29, 2015 04:35 PM
thegipper
Sep 28, 2015 01:01 PM
