Knock Sensor - P0320???
Old Jun 13, 2007 | 11:53 PM
ussi's Avatar
I (don't) whine.
So recently i've had a CEL code - P0320 or 0375 i don't remember which. But I got it read and its the Knock sensor.
Now I thought I could have excessive pinging b/c all the engine work i recently got done - new cats, port polish, new valves, cams, etc. but the code came on like 3 weeks after i got all the work done. I talked to the dealer and my mechanic and they both said they see this problem when the knock sensor wire has been detached (from a rat chewing though it or something, but trust me there is no way a rat got in there) So its going to be like $350 for the labor to remove the intake manifold and replace the wire and sensor.
Anyone else have this happen to them?? Any ideas besides what the dealer/mechanic's ideas?
Old Jun 14, 2007 | 12:41 AM
ussi's Avatar
I (don't) whine.
oh and i have reset the CEL twice, and it turns on IMMEDIATELY upon restarting the car (well, in the parking lot rather) which makes me believe it is an electrical issue, not mechanical.
Old Jun 14, 2007 | 10:07 AM
rbf351's Avatar
Registered User
if the sensor is broke or the wire is disconnected you won't be able to stop the CEL. only choice is to get it repaired
Old Jun 14, 2007 | 05:48 PM
Xx06SickspdTlxX's Avatar
06 TL 6spd. Navi/A-spec
I wouldnt say that a rat couldnt have gotten in there, this is a very common problem with the v6 engines, the knock sensor and wire harness is located between the two heads right under the intake manifold, rats like to nestle in there because it is warm and the only thing that they see is the knock sensor and harness. Being a honda tech for a few years i have replaced handfuls, there is even a service news bulletin on this. This may not be your case for the knock sensor dtc, but i wouldnt doubt it!
Old Jun 14, 2007 | 07:03 PM
ussi's Avatar
I (don't) whine.
It still sounds unbelievable to me, but the techs and service advisers were pretty confident that was the problem. So my service adviser just called me and said that the wire was OK, so they're going to replace the sensor and cover it under warranty! I hope thats the last i have to deal with this.
Old Jun 15, 2007 | 04:48 AM
ussi's Avatar
I (don't) whine.
bad news..
Its P0325.
I got the sensor and wire replaced by the dealer under warranty. So I turn on my car and it the CEL come back on right away. AHH soo frustrating. Dealer thinks it could be anything..but leaning towards electrical. But since i recently had alot of work done on my car, its hard to know where to pin point. For now I have my car back, I don't know what to do.
Old Jun 15, 2007 | 05:09 PM
There could be an open or short in the harness between the pcm and the knock sensor, or an open in the wire.
Old Jun 16, 2007 | 04:08 AM
ussi's Avatar
I (don't) whine.
thats the only thing i could come up with. my mechanic is going to check the rest of the wires monday or tuesday hopefully.
Old Jun 16, 2007 | 03:57 PM
encrypted03's Avatar
The only thing I could come up w/ in regards to the knock sensor could be found in this thread:
https://acurazine.com/forums/showthr...t=knock+sensor
But since the code is P0375 (Timing reference, high resolution signal B – malfunction Wiring, CKP/RPM/CMP sensor, ECM) I'm not sure if that'll even help.
Old Jun 16, 2007 | 04:27 PM
ussi's Avatar
I (don't) whine.
Good find! Thanks, I searched for this but missed this thread. I think I'm going to follow the instructions in that thread.
I hope comptech is open Monday 18th if i need tech support .
oh, its P0325.
RobbDizzle
Oct 15, 2015 11:16 AM
thegipper
Sep 28, 2015 01:01 PM
hrothgar02
Sep 28, 2015 11:08 AM
prbori
Sep 27, 2015 01:37 AM
STL TL-S
Sep 23, 2015 08:52 PM
