Key Program
Old Jul 12, 2015 | 05:37 PM
Nia2x's Avatar
4th Gear
Key Program
How do I program my key to the car?
Old Jul 12, 2015 | 05:59 PM
tk2k6's Avatar
First you need a key blank. Preferably the OEM which is 35113-SEC-A01, then you go to a locksmith which will charge you anywhere from $40 to $50 to laser cut it and program it. You need your original key to read the chip info from and write it onto the newly cut key, of course.
Old Jul 12, 2015 | 07:37 PM
Nia2x's Avatar
4th Gear
It was already once programmed. My car reset when I had to take the battery out to put a new starter in.
Old Jul 13, 2015 | 12:45 PM
Will Y.'s Avatar
Registered but harmless
Do you need to reprogram the remote, or re-link it?
The 3G TL Service Department/Garage thread is at: https://acurazine.com/forums/third-g...ewbies-553554/.
Linking the remote is necessary if a remote opens the doors, but does not detect the driver settings set with the DPMS.
Linking the remote is in the owner's manual available on line through: https://acurazine.com/forums/third-g...t-pdfs-851625/.
For new remotes or ones that have lost all settings, the programming procedure is in: https://acurazine.com/forums/third-g...-079-a-556315/.
Welcome to AZ.
Old Jul 13, 2015 | 10:50 PM
Hi speed's Avatar
runnin a little boost
This will not deprogram the keys, what is happening with the car? The immobilizer info is saved and not effected by pulling the battery cable.
Old Jul 18, 2015 | 12:08 PM
Nia2x's Avatar
4th Gear
I really dont know what happened to the key.. We took out the battery to put a starter in.. Once we got everything back in, the remote wasnt linked anymore.. I can't even turn the key in the door to lock it..
Old Jul 18, 2015 | 12:35 PM
screaminz28's Avatar
I can't decipher what the problem really is - Does your key not start your car? Or does the remote just not unlock the door?
If its the remote - that just needs to be linked, and you can do it yourself.
If the key doesn't start the car, something else is happening with the immobilizer.
Based on your posts, and the fact that you said the key won't turn in the door now, my guess is that ONLY the remote isn't working, but the key works in the ignition, and since you had a remote, you never tried it in the door. Flip the key around and see if it works in the door. They are symmetrical, but sometimes not cut properly.
soupi
14
Nov 15, 2015 11:15 AM
eastcoastguy
Oct 29, 2015 03:00 PM
joflewbyu2
Oct 8, 2015 11:16 AM
malvothegreat
Sep 29, 2015 12:38 AM
Sue1910
2G CL Problems & Fixes
Sep 27, 2015 12:34 PM
