Justnspace vs J32/J37
Old Aug 20, 2014 | 08:38 AM
  #161
FamilyGuy's Avatar
Oh ok. So no need to take them out for powder coating then? I got new covers and will have them coated locally, but the covers came with the seals already installed among a few other things already there too. I also got a gasket kit for each cover, wondering if I need it, or if these gaskets are the same ones. Hard to tell through the bag, but at least some look new, i.e. not included with each cover.
  #162
^originally, i thought you had to bake the valve covers in the oven to produce the wrinkles.
I had bought the gasket kit, which came with tons of gaskets. including these.
i then started pulling on them which ripped them. at that point, I was all in and had to replace them
Old Aug 20, 2014 | 08:41 AM
  #163
rockstar143's Avatar
If you have gone on the mission to remove your valve covers, fk that sh*t, swap ALL the gaskets over...the bolt ones fkng SUCK to swap over to the original bolts, but I'd suggest doing that too...lube them all with fresh oil too.
Easiest way to do the bolt that I found was hold with a paper towel to avoid rubbing your fingers raw, lube with oil, then press with palm of hand like a syringe to pull the new gasket washer on.
You'll know...mine were brittle and shrunken, only a matter of time before you have oil weeping out of the cover if you don't swap them all.
Old Aug 20, 2014 | 08:55 AM
  #164
FamilyGuy's Avatar
Awesome, will do.
And yes that's right justn, I forgot that normally they will go in the oven at like 400F or something so ok, I'll remove everything.
I ended up buying new covers and they came with some of the bolts and seals installed, but I also got the gasket kits since I didn't know they came that way. I hesitated buying new covers at first but one has the pcv nipple corroded and after talking to the powder coat guy, he said if there are baffles in there, which there are, he said no sand blasting, cuz some will trap in the baffle and may end up in the heads. So I just said f* it I'm already in the hole for one cover might as well get the other one, get them coated and installed. That way if there are any surprises when the original rear one comes off the car I won't be going back and forth crazy. And I didn't see myself trying to clean 7 year old dirty covers by hand...
I'll use your tip with the flathead to remove the seals.
Old Aug 20, 2014 | 09:00 AM
  #165
Yeah, definitely man...good thinking!
LOL...I literally had to do buy and pick up at store 2 days in a row to buy new fel-pro gasket kits from my local advance auto...the guy was like, wtf happened, man.
Just said I was dumb...
I wasted about 5 hours on getting the spark plug gasket onto the tube the right way...that part sucked. I wish I had paid attention to how they came off to begin with.
Old Aug 20, 2014 | 09:05 AM
  #166
FamilyGuy's Avatar
Haha right I've been going to pick up parts at Delray Acura all week like 3 times already. The last time the guy was like "didn't you just get your parts before yesterday?" They must think I'm crazy, which is probably true I just keep saying to myself "a boat would be worse, a boat would be worse" and keep on trecking. I'm going back to pick up the rear cover as soon as it comes in lol
But yeah what started as a simple PnP job on the TB and manifolds has turned into a little engine porn job. If only things weren't so fugly underneath that plastic cover, but I guess that's the benefit of using an engine cover
Old Aug 20, 2014 | 09:23 AM
  #167
Yep...at this point, I know all the guys from Acura of Pembroke Pines...sales, parts, service, even the techs...first name basis.
They're awesome...my home away from home.
Old Aug 20, 2014 | 10:03 AM
  #168
Majofo's Avatar
So this is where you've been hiding your shame.. I knew you'd fk this up
I fucking made a picture.. fucking fool proof.. I guess not.
Old Aug 20, 2014 | 10:04 AM
  #169
Majofo's Avatar
Where's my thanks on the heads installation..
Old Aug 20, 2014 | 10:05 AM
  #170
i only looked at your DIY after I fucked up.
Old Aug 20, 2014 | 10:10 AM
  #171
Majofo's Avatar
Likely excuse
Old Aug 20, 2014 | 10:46 AM
  #172
bp_spets's Avatar
So you're not doing anything for tuning after putting bigger heads on? You're hoping the stock ECU has enough slack in its tables to handle it?
Old Aug 20, 2014 | 11:19 AM
  #173
you gonna scare Justin, man...
Majofo, your bible was a bible.
Old Aug 21, 2014 | 10:56 AM
  #174
gnuts's Avatar
3.5 psi
finally made my way to your thread. Who knew there was a whole section devoted to the 3rd gen TL.
in for results!
Old Aug 21, 2014 | 11:10 AM
  #175
Majofo's Avatar
in for results!
Unfortunately there's a section for 4G and 5G as well.
Old Aug 21, 2014 | 12:37 PM
  #176
Yumcha's Avatar
Majofo knows his stuff.
Old Aug 23, 2014 | 02:17 PM
  #177
Grand_hustle17's Avatar
Cant wait for before tune dyno numbers and after...
Old Aug 23, 2014 | 02:33 PM
  #178
if you havent seen
this was with PCD's and Jpipe, everything else stock.
*Update*
I got the lower cover and side mount on.
I also cranked it 6 times and each pulley is at TDC.
Old Aug 23, 2014 | 02:38 PM
  #179
Majofo's Avatar
Old Aug 23, 2014 | 02:50 PM
  #180
Old Aug 24, 2014 | 11:00 AM
  #181
how come the 2nd one always comes out better?
lol, at least I tackled the spray painting learning curve!
Shows the side mount and cover on. I ended up just forcing that motherfucker in there with the help of bada$$vtec
getting ready to adjust valves
and uh oh! I snapped the bolt head off of the front engine mount.
Old Aug 24, 2014 | 11:16 AM
  #182
Slpr04UA6's Avatar
-------Tim-------
Nice!
Then Fuck! Something always doesn't go smoothly! Good Luck with the removal!
Old Aug 24, 2014 | 11:44 AM
  #183
Majofo's Avatar
Why you always breaking things?
Old Aug 24, 2014 | 12:18 PM
  #184
nfnsquared's Avatar
Yeah, this thread should be re-titled to:
How not to do the 105K service
Old Aug 24, 2014 | 01:12 PM
  #185
gnuts's Avatar
3.5 psi
Did you paint the rear cover first? Looking good.
Old Aug 24, 2014 | 02:37 PM
  #186
Fuck playing around with the breaker bars!
bought a drill extractor kit.
Didnt work
Old Aug 24, 2014 | 03:23 PM
  #187
Yumcha's Avatar
Holy crap. Good luck removing bolt.
Old Aug 24, 2014 | 03:52 PM
  #188
Justin, try centering a very small bit and drill out the center of the bolt, using increasing sizes...as it nears the edges of the threading (before it hits threading and ruins it) it'll likely release the pressure that's holding the bolt in place and will just come right out.
Good luck, man. Small victories.
Old Aug 24, 2014 | 05:10 PM
  #189
Majofo's Avatar
Small penises.
Old Aug 24, 2014 | 05:11 PM
  #190
EvilVirus's Avatar
We did that but the drill bit didn't pierce through the center. If you look at the picture there is a metal piece that is stopping the drill bit from going any further.
Old Aug 24, 2014 | 06:08 PM
  #191
in that case, you should have been able to kinda force a smaller extractor bit in there to coerce the rest out.
Old Aug 24, 2014 | 08:00 PM
  #192
gnuts's Avatar
3.5 psi
I once used a bigger bit and started into the bolt and when it got hard I put a lot of weight on it and reversed it out. Have you been soaking it with a penetrant spray?
Old Aug 24, 2014 | 08:44 PM
  #193
The easy answer is to acquire a used front mount.
Old Aug 24, 2014 | 08:46 PM
  #194
And I actually broke the front mount weeks ago.
I saw the bolt was loose and I over torqued it.
Old Aug 24, 2014 | 08:52 PM
  #195
Majofo's Avatar
Justn likes it loose and easy..
Old Aug 24, 2014 | 08:55 PM
  #196
Yumcha's Avatar
So, friendly e-bets to when Justin gets this car back on the road again...?
Set the over/under to 3 weeks?
Old Aug 24, 2014 | 09:04 PM
  #197
nfnsquared's Avatar
^^^^ dunno, but it will be directly proportional to the number of bolts left to loosen/tighten
Old Aug 24, 2014 | 09:07 PM
  #198
Majofo's Avatar
I'll take a bet on how long his car lasts on the road before it's back on jacks.
Old Aug 24, 2014 | 09:09 PM
  #199
nfnsquared's Avatar
^^^^ inversely proportional to the number of trees/curbs in the area
Old Aug 24, 2014 | 10:03 PM
  #200
EvilVirus's Avatar
