Justnspace vs J32/J37
Old 08-16-2014 | 08:16 AM
  #121
so, now....
I just have to adjust valves.
paint covers.
and put everything back together.
I had gotten a little discouraged last weekend.
and its just best to take a break and start fresh.
Old 08-16-2014 | 08:21 AM
  #122
Change oil and coolant
Old 08-16-2014 | 08:38 AM
  #123
rockstar143's Avatar
Did you swap over the insert for the timing belt tensioner pulley...be sure to or when it moves it'll not clear the water pump.
Old 08-16-2014 | 08:40 AM
  #124
Valve Adjustment isn't bad...
Do it twice to get be sure, then use your torque wrench to set all the locking nuts back to 14 ft/lb
I took NFN's advice and went high tolerance on exhaust side and low tolerance on intake side since they tend to end up too tight/loose (ex/in).
I want to say .008 intake and .013 exhaust, but don't quote me, that's on memory.
Old 08-16-2014 | 08:41 AM
  #125
this insert????
Old 08-16-2014 | 08:51 AM
  #126
Oui, Monsieur!
Old 08-16-2014 | 09:10 AM
  #127
better pic of the timing belt
Old 08-16-2014 | 10:00 AM
  #128
Double check that your slack is in the right places before pulling that pin
Old 08-16-2014 | 10:20 AM
  #129
yungone501's Avatar
J-series addict
Ah man, my old age is wearing through. Sorry Justin.
"Stripper name".....lmao
Old 08-16-2014 | 10:25 AM
  #130
Welcome Robert to the main stage!
Old 08-16-2014 | 10:28 AM
  #131
the slack is in between the two pulley's right!@?!??!
i already pulled the pin
Old 08-16-2014 | 10:30 AM
  #132
omfg you're scaring me Jeremy
I think i did it correctly
Old 08-16-2014 | 10:35 AM
  #133
timing belt showing TDC. its hard to get it exact, I did the best I could.
next step is to adjust valves.
and in case some one didnt have the service manual the valve specs can be found on the inside of the hood
Old 08-16-2014 | 10:41 AM
  #134
nfnsquared's Avatar
If you followed the SM procedures for looping the belt, you're fine...
Old 08-16-2014 | 10:45 AM
  #135
LOL...hey, better to be scared and check everything twice BEFORE you go boom again!
You're fine...go over Maj's 105K diy one last time before you bolt covers on.
Old 08-16-2014 | 10:47 AM
  #136
nfnsquared's Avatar
Oh wait, this is Crabman that we're talking about. Disregard the above.
^^^^ Fixed
Old 08-16-2014 | 10:52 AM
  #137
Old 08-16-2014 | 10:53 AM
  #138
nfnsquared's Avatar
And it will be easier if you remove the individual feeler gauge blade/s from the holder...
That set is pretty short. I'd recommend trying to find a longer set if you can.
Old 08-16-2014 | 11:16 AM
  #139
I think he's on a time crunch...they'll have to do.
I agree though, and more important than the length, make sure the girth...oh wait, never mind.
Actually, I found that even with my long ones...was MUCH easier for me once I put a slight bend on the end, about 3/4" up from the tip.
Old 08-17-2014 | 09:11 PM
  #140
I indeed installed the belt wrong.
Thank you rockstar and nfnsquared for picking up at the small details.
I installed the belt clock-wise and not counter-clockwise like the service manual stated.
I had already pulled the pin.
i uninstalled the belt which left me with a slight problem. the tensioner spring was already activated!
I tried to use my table top vice, but it wasnt large enough to fit the tensioner.
so, I went to my favorite exhaust shop. took it to my guy and he re-installed the pin in a matter of seconds. for free.99
in hind sight, I think I could have used a C-clamp.
re-installed the belt the correct way. this time, timing on all three pulley's lined up PERFECTLY.
however, now i'm stuck on installing the side mount and lower timing belt cover.
I cant seem to logically install it. it wants me to force it in, when I know that it shouldnt be forced in.
in the mean time; I decided to paint.
I also found a very easy way to uninstall the spark plug seals underneath the valve covers.
insert a flat head underneath the seal and twist.
FamilyGuy (08-18-2014)
Old 08-17-2014 | 09:26 PM
  #141
Yumcha's Avatar
So how many more hours do you estimate this will take, J...?
Old 08-17-2014 | 09:27 PM
  #142
^a long fucking time.
i'm so frustrated.
Its hard to work on it during the week( work and family) and then on when I do get a chance to work on it on the weekends, i run into problems after problems after problems.
I just want to get it right, so I'd rather take my time and solve problems one at a time.
my one friend who has done this before is busy with a new family. so, i'm just trying to take it one day at a time.
Old 08-17-2014 | 09:29 PM
  #143
Yumcha's Avatar
i'm so frustrated.
Well, FWIW, you are learning lots about the car...and definitely ambitious in taking this project pretty much on your own with some help by the peeps on this site.
The experience will be priceless I'm sure.
The following 2 users liked this post by Yumcha:
Aman (08-18-2014), Costco (08-17-2014)
Old 08-17-2014 | 09:35 PM
  #144
nfnsquared's Avatar
Amazing how much better it is when you follow directions
...however, now i'm stuck on installing the side mount and lower timing belt cover.
I cant seem to logically install it. it wants me to force it in, when I know that it shouldnt be forced in. ...
Just to be sure: You install the side mount first, then the lower TB cover. I f'd that up and had to go back and take the lower TB cover back off
I don't recall any issue once I did it in the correct order...
i'm so frustrated.
You're closer than you think...Keep you chin up
Old 08-17-2014 | 09:39 PM
  #145
that's the correct order.
however, there is a pulley in the way.
the mount is no problem to install.
I just cant figure out a way to finesse the lower cover underneath the side mount and wedge into place behind the pulley.
this is the pulley that you can move from side to side.
Old 08-17-2014 | 10:20 PM
  #146
yungone501's Avatar
J-series addict
Not sure if anyone has mentioned this or not yet but after the belt has been installed and the tensioner released its a good idea to turn the engine over at least TWO full rotations before moving onto the next step. After spinning the motor over, recheck the belt tension to ensure that its within acceptable range. Doing this will tell you 100% if the belt was installed correctly or not and alleviated any fears of that initial fire. Lol, cause when you're not sure, it's somewhat like a Russian roulette.
Good progress so far!
Old 08-18-2014 | 09:38 AM
  #147
Yeah, and after each full rotation double check that all TDC's line up.
Justin, did you get my text with a picture of how everything came off and went back on?
Also, can you take a picture of the pulley you're talking about please. Did you accidentally put the idler/tensioner pulley assembly back on FIRST?
You must first do side mount, then bottom cover (made same mistake as NFN...bottom cover covers one of the bolts that holds side mount). Tensioner assembly doesn't go on until much closer to the end.
Old 08-18-2014 | 09:39 AM
  #148
accessory belt tensioner, I mean...not TB, obvi.
justnspace (08-18-2014)
Old 08-18-2014 | 09:47 AM
  #149
^ahhh.
we didnt take off accessory belt tensioner. we just moved it to the side to get the lower cover off.
Old 08-18-2014 | 10:03 AM
  #150
Funny, now that I look at your pictures, I should have caught that it was in the way!
Old 08-18-2014 | 10:09 AM
  #151
good shit rockstar.
I was so frustrated with it on Saturday. lol
rockstar143 (08-18-2014)
Old 08-18-2014 | 10:27 AM
  #152
Tell me about it, man...
I knew that when you said you were having to force something, something wasn't right. Although stuff was cumbersome and tight spaces, nothing needed to be forced into place.
Glad you got it figured out, man. What's your deadline again? This Saturday coming?
Old 08-18-2014 | 11:58 AM
  #153
Vlad_Type_S's Avatar
Registered Bike Offender
Way to go, crabs! Keep up the good work. You can't even be mad at the problems though because you're spending the extra time to make sure everything is perfect. Be proud of that ish.
Old 08-18-2014 | 02:01 PM
  #154
Old 08-18-2014 | 05:14 PM
  #155
kingkong_dav's Avatar
KingKong_Dav
That shit look like it have slack on the belt my boy
Old 08-18-2014 | 06:03 PM
  #156
it did, it's because he routed the wrong way, man. That's why all his TDC's weren't perfect.
Old 08-20-2014 | 08:21 AM
  #157
yungone501's Avatar
J-series addict
We wanna see some videos...
Old 08-20-2014 | 08:25 AM
  #158
They're coming, I'm sure Justin is almost done.
The crinkle red looks awesome, btw, Justin.
Old 08-20-2014 | 08:29 AM
  #159
FamilyGuy's Avatar
...I also found a very easy way to uninstall the spark plug seals underneath the valve covers.
Why did you take these out? Why not just mask them off?
Old 08-20-2014 | 08:32 AM
  #160
Those are the rubber o ring seals for the spark plug tube to ensure you don't end up with oil in there...good practice to swap them out with your valve cover gasket since they come in the set anyway, Ivo.
Quick Reply: Justnspace vs J32/J37
