Jerkiness when changing gears
Old Jun 10, 2009 | 11:11 AM
shobe80's Avatar
So I bought my 2005 TL a couple of months ago from a local dealer. Four days after I bought it the engine just quit on me. It's a long story...suffice it to say it was kind of a freak thing with the cooling fan breaking off, shooting into the radiator and draining all of the fluids. The whole engine had to be replaced...thank god I bought the extended warranty through Zurich.
The thing now is the car kind of jerks when it changes gears. It's not as smooth as I thought it would be. I'm not sure if it's due to the new engine, as I can't really remember how it was in the four days prior to the engine going out. It's especially noticeable when it shifts into second. I don't know if all TL's are a tad jerky when switching gears, or if it's definitely something I should ask the dealer about. Any thoughts/ideas? Thanks guys.
Old Jun 10, 2009 | 01:43 PM
NedShneebly's Avatar
practicing nihilist
when you are accelerating like an old man - 1/4 pedal in the slow lane - it should be buttery smooth, assuming you have not modified any components.
Old Jun 10, 2009 | 03:48 PM
Meek32v6's Avatar
I like to whistle in my
mine shifts hard when the fluid is getting dirty. (I actually don't mind it
check the tranny fluid to see if it is low or needs to be changed.
Also -I've read if you are using something other than HONDA Tranny fluid then the shifts can be slighlty harder too.
Old Jun 10, 2009 | 04:06 PM
practicing nihilist
true. Amsoil (Z1 approved) or Royal Purple will stiffen shifts up a bit. I'll let you know next week. I'm about to drain and flush with Amsoil UTF.
Old Jun 10, 2009 | 09:06 PM
Elegant TYPE S's Avatar
Being an Acha Bacha in
Check out this thread, seems like this is working for a lot of people. I'm going to do it as well.
https://acurazine.com/forums/3g-tl-2004-2008-93/very-interesting-conversation-my-transmission-builder-tl-721508/
Old Jun 10, 2009 | 11:02 PM
NAiL05's Avatar
If your cooling fan broke before the new engine...I would assume engine mounts are already out if not most on the way. Did they change those with the engines? If they havent that would be what I would check first.
Feb 25, 2020 09:57 AM
George Knighton
3G RLX (2013+)
176
Sep 16, 2016 08:26 PM
JetLife2324
Sep 17, 2015 05:59 PM
phillyguerrilla
Sep 11, 2015 06:39 PM
Aleax
Sep 11, 2015 11:31 AM
