Issues after ecu replacement
07 TL -original ecu went bad. Replaced ecu, ignition switch with matching key.
Car starts and runs OK, but no radio/nav/ heat and I have a noisy fan.
Any recommendations for next step, thanks
Check the fuses, usually when the ecu poops it blows a couple fuses, if all that is ok make sure everything got connected correctly to the ecu
Laszlo (01-29-2018)
Laszlo (02-03-2018)
OK. The heat seems to be working.
i checked the fuses to the radio and they are OK. When I reinserted the fuse, I could hear some resetting, but no display on NAV, no power to radio.
i also noticed that my settings are not being saved and are being reset every rime I turn on ignition.
- Radio resets to 1:00
- trip meter goes back to zero
- Heater setting to low
Any help would be appreciated
