Intermittent starting problem
Old May 8, 2013 | 01:44 PM
msauer's Avatar
3rd Gear
At times my 06 tl will not turn over. If I shake the steering wheel and try again, it will start right up. Has anyone else had this problem? Any ideas on a possible solution?
Old May 8, 2013 | 02:06 PM
erdoc48's Avatar
06 Anthracite TL
Try to be a little more specific:
-does the starter tun, but the engine will not fire, or
-turning the key results in no electrical activity and the starter will not even turn? Then you turn the wheel a little and it starts?
It'll help with your problem if we know.
Old May 8, 2013 | 02:20 PM
msauer's Avatar
3rd Gear
The starter does not turn. You turn the key and nothing happens. I don't turn the wheel a little, I shake the steering wheel and it starts right up.
Old May 8, 2013 | 03:08 PM
erdoc48's Avatar
06 Anthracite TL
OK, that is a bit more helpful- that sounds like it's the actual key switch that may be faulty or the immobilizer- loose wire or short circuit. I'll check the 3G garage and see if there's anything there regarding the starter switch
Old May 8, 2013 | 05:27 PM
msauer's Avatar
3rd Gear
Thank you.
Old May 9, 2013 | 08:28 AM
erdoc48's Avatar
06 Anthracite TL
Originally Posted by msauer
Thank you.
Shoot me your email via PM and I have some information from the manual that might be helpful
Powder Monkey
2G CL Problems & Fixes
Sep 9, 2018 12:55 AM
obert
Dec 14, 2015 11:36 PM
siularbar
1/2G MDX (2001-2013)
Sep 11, 2015 10:40 AM
jordanboi
Sep 5, 2015 01:33 AM
NSolace
Sep 3, 2015 08:02 PM
