Intermittent crank/ no start p0335
Old Aug 20, 2019 | 11:11 AM
Blacura2005's Avatar
4th Gear
Hey guys,
I’m dealing with an issue I am having with a 2005 TL auto with nav. Initially the car would not start, only code was P0335 ( crank position sensor) . I replaced the fuel pump relay and realized the car had little to no gas (added gas) and started up and ran fine for 2 weeks.
And than I got a service engine soon B message, car ran rough and it would not restart. The P0335 code came back. After a few days I tried again and it started back up and ran ok but I’m going to do some service and hopefully pinpoint the issues before trusting it as a daily. My question is: Should I replace the crank position sensor? Is this code common and is this a common fix, or possibly PCM? ( appeared to be dry and free of corrosion). I’m definitely doing plugs and all other maintenance. Anybody deal with this? Any help is appreciated, I can answer and follow any instructions that can help you help me.
Thanks again,
Paul
Old Aug 20, 2019 | 11:14 AM
4th Gear
Additional info: car has had battery, alternator, battery cables and timing belt replaced within last few years.
Old Aug 20, 2019 | 01:17 PM
El_Cheapo's Avatar
So you saw a P0335 for the crank sensor and that lead you to replace the fuel pump relay?
You can eliminate battery/starter by having them tested at Autozone or any other parts store. Also, are you certain it's not the immobilizer?
A bad crank position sensor (CKP) will cause a crank-no start issue.
First, just do visual inspection. Look for chaffed harness, loose connector, corrosion, etc. If everything looks good, then you're going to have to do some diagnostics.
If you have a scanner or maybe even a BT OBDII plug with Torque, you can look at RPM data while you crank. If the the car cranks and the RPM on the scanner is at 0 RPM, then that means that PCM is not seeing the CKP signal. You'll need to check the sensor 5-volt, ground, and signal.
Old Aug 20, 2019 | 05:28 PM
4th Gear
Thanks for the response. Initially I thought it was a fuel problem. I looked into recalls and noticed the fuel pump relay was recalled and updated. My car still had the old relay so I figured I’d replace regardless. After that it seemed like smooth sailing until now.
I will check the rpm data tomorrow but at the moment the car has no issues. I definitely need to visually inspect the sensor, I have yet to figure out where it is so I’ll do some research tonight.
I want to say I’ve ruled out the immobilized because I have different keys. However I do remember seeing the green key emblem flash while the car was giving me issues. How can I officially rule that out?
Thanks again. I will post my results tomorrow around this time.
Old Aug 20, 2019 | 06:34 PM
The crank sensor is located behind the crank pulley. #16 & #17 display the sensor and harness on the link below:
https://www.acuraoemparts.com/v-2005...gine--oil-pump
Old Aug 21, 2019 | 07:35 AM
4th Gear
Thanks for the schematic!
Also I just realized I need to edit my post. The code is P0336, not P0335.
Old Aug 21, 2019 | 02:26 PM
El_Cheapo's Avatar
If the car is working normally then you won't be able to diagnose a problem that isn't there. So there is no point of looking at the RPM data right now other than just for you to know what is good cranking speed. FYI, starting crank is 200-300 RPM.
Since you're car is working fine now, take a look at the immobilizer green key light flash duration. That way you'll know what good is. Also note that the immobilizer system only disables the fuel pump so keep that in mind.
Also, just because the fuel pump is working does not mean you don't have a fuel problem.
Old Aug 21, 2019 | 09:53 PM
csmeance's Avatar
get the proper code my friend:
Old Aug 21, 2019 | 09:57 PM
csmeance's Avatar
csmeance's Avatar
Old May 19, 2026 | 09:30 AM
Cthulhuy's Avatar
Good morning, thank you for providing these instructions. I know this was an old thread, but once I finish my diagnosis I will share later for anyone else who may have similar issues. After looking at my TL’s setup, I believe the G101 may be the culprit, but I’ll need to follow this diagnosis procedure before I begin any kind of parts replacement.
Originally Posted by csmeance
Carley C Rando
Feb 18, 2019 11:41 AM
425TL
May 11, 2017 07:50 PM
Total2f
Feb 13, 2015 07:14 PM
Manimal_Forever
Oct 16, 2012 11:19 AM
amsmk
Nov 6, 2006 10:42 PM
