I am stuck
Old Feb 18, 2014 | 03:38 PM
rick2v's Avatar
3rd Gear
I am stuck
My 2005 TL, 6 speed, Great car but a few new issues. The mirrors no longer rotate down when you put in reverse. Also the windsheild washer has quite working. I replaced the pump still does not work. Are both isses related?
Old Feb 18, 2014 | 03:40 PM
check fuses.
Old Feb 18, 2014 | 03:57 PM
Ron A's Avatar
Administrator
Welcome to the forum.
The forum where you originally posted, The AcuraZine User Help, Support & Suggestions Area , is meant for problems, comments, and suggestions for the website itself, so I moved your thread to the car specific forum applicable to your vehicle.
Old Feb 18, 2014 | 04:11 PM
bp_spets's Avatar
I believe its a common fuse between the windshield washer pump and the mirrors, and there is a TSB out there to replace it with a higher amperage fuse. So check your fuses
Old Feb 18, 2014 | 05:17 PM
Will Y.'s Avatar
Registered but harmless
If so, some of your driver's seat controls should be out too.
Replace the 7.5 amp fuse with a 10 amp fuse in the #20 spot in the underdash fuse block-- that is per TSB.
That should bring the mirrors, seat and wiper motors back to normal.
Welcome to AZ.
Old Feb 18, 2014 | 05:43 PM
Will Y. to the rescue, yet again!
Old Feb 18, 2014 | 06:08 PM
Will Y.'s Avatar
If only... See OP's original thread at: https://acurazine.com/forums/3g-tl-problems-fixes-114/washer-dead-mirror-control-issue-2005-tl-904184/ .
Old Feb 18, 2014 | 07:42 PM
nfnsquared's Avatar
OP, replace the fuse even though you think it's good...
SidhuSaaB
May 30, 2020 12:40 AM
Jul 16, 2017 07:33 AM
carz0159
Sep 20, 2015 06:11 PM
