How replace molding by door handle.... HELP
AMFTW
I've done some research but have come up empty, other threads did not have
images to show problem so I'm hoping in doing so will get this problem solved.
![](http://i278.photobucket.com/albums/kk94/ripleejr/door2.jpg)
![](http://i278.photobucket.com/albums/kk94/ripleejr/door3.jpg)
![](http://i278.photobucket.com/albums/kk94/ripleejr/door1.jpg)
I do know that the door panel has to be taken of.. correct? If so above is my current
progress. I've taken off 4 screws. I need to know if there are any others hidden that
need to be removed, if not do i now pop it off? Is there any difficulty putting
everything back together again or is it fairly simple?
Any advice from similar
experiences would be greatly appreciated. I do have the replacement part with the
molding and the base. Just need access to unscrew old base and replace with new
part
part
AZ Community Team
Received 7,771 Likes
What are you trying to do?
Just replace that peice that is missing in the first pic?
If so, just get a new one and pop it on. ~$10. There is actually a TSB for this and the dealer might do it gratis. No need to go fooling with the door panel or extra screws or whatever.
If you're talking about removing/shaving the door handles, that is something else entirerly.
Try These:
E-022: DIY: Driver side door lock MOD
https://acurazine.com/forums/showthread.php?t=82775
https://acurazine.com/forums/audio-video-electronics-navigation-22/quick-question-aftermarket-hu-125597/
F-016: DIY: Front/rear door panel/handles/wstrip/glass/window regulator removal
https://acurazine.com/forums/car-talk-5/my-car-super-street-143797/
https://acurazine.com/forums/ramblings-12/trance-list-93985/
Try These:
AMFTW
Try These:
https://acurazine.com/forums/showthread.php?t=125597
https://acurazine.com/forums/showthread.php?t=143797
https://acurazine.com/forums/showthread.php?t=93985
Try These:
Originally Posted by riplee
Yes I'm trying to replace that piece in the 1st & 2nd pic, it fell off when i drove home from work. I did try to snap the molding piece on but the base part (ugly metal thing) won't grasp the molding correctly and does not stay on. The base needs to be replaced as well so thats why i'm asking about how to get into the door. thx
AZ Community Team
When I try and look at the TSB 07-043 I get this message:
You are not authorized to view the content on this page.
If you believe you have received this message in error, please contact the Support Center.
Please go back or return to the home page.
I just tested the bulletin and it opens for me.
You have to follow the instructions exactly as they are posted, including clearing your cache if you are using Firefox and probably some other sites.
https://acurazine.com/forums/3g-tl-2004-2008-93/3g-tl-technical-service-bulletins-tsbs-3g-garage-j-016-a-613659/
Try These:
Try These:
rockyboy
08-04-2024 10:35 AM
tman570
06-11-2019 07:56 AM
