How to replace gear position sensor O-Ring?
Old Nov 26, 2011 | 09:56 AM
guitarplayer16's Avatar
Hey,
As some of you may know I have ATF leaking at the gear position sensor.
I believe Majafo mentioned in a thread I made earlier that there's an o-ring behind there that can be changed.
My mechanic that I went to a few days ago who removed my one shock (with broken pinch bolt) also said that there'es an o-ring that can be changed behind there.
Is there some sort of page out of the service manual or if anybody knows the instructions to replace the o-ring?
Thanks!
Old Nov 26, 2011 | 11:12 AM
Bearcat94's Avatar
AZ Community Team
If you look here: http://www.acuraautomotiveparts.org/...s=&view=normal
It looks like it might be just as easy as removing the switch/sensor then replacing the o-ring.
Edit:
Not sure this is your exact solenoid, but pretty much everyone I saw in the SM is about the same as far as showing O-ring replacement.
Old Nov 26, 2011 | 06:37 PM
Thanks Bearcat!
You always seem to have answers for my problems!
You mechanic also stated that I had to pop off the sensor and just replace the o-ring inside but there's a few bolts connected to the sensor I don't know which one to remove LOL
Also I wonder if ATF will gush out if I remove the sensor haha
mada51589
Jan 9, 2025 04:40 PM
Feb 25, 2020 09:57 AM
cycdaniel
Dec 17, 2019 10:58 AM
DwDrummer
5G TLX Problems & Fixes
Sep 14, 2015 08:20 PM
NSolace
Sep 3, 2015 08:02 PM
