How many quarts of Transmission fluid?
Hello,
I was thinking of getting a transmission fluid flush on my 2006 Acura TL (5AT). I want to buy the fluid myself and have a local mechanic perform a 3X3 drain/fill procedure. My question is, how much fluid does the transmission take? With 3X3, is the transmission capacity for fluid 9 quarts?
I am thinking of buying this one:
http://www.amsoil.com/catalog.aspx?GroupID=206
From what I understand there is about 8 quarts of transmission fluid in the system, a 3x3 will require 9 quarts because each time you do it you will only be able to drain out 3 quarts.
I would recommend using Honda AFT DW-1, this is also pretty easy to do yourself if you have a ratchet set, a breaker bar and a container.
Cheers.
Cheers.
SidhuSaaB
May 30, 2020 12:40 AM
