How many amps to HID's pull ???
Old Mar 8, 2011 | 10:13 AM
MattB07TL's Avatar
How many amps do HID's pull ???
Threw some hid's in my fog's worked for a day or 2 and blew the 10 amp fuse, So I put a 15 amp and it blew that . Anyone know how many amps they pull? and is that going to be dangerous to put a big fuse in there if its only supposed to take a 10 amp? Thanks
Old Mar 8, 2011 | 10:14 AM
i believe you would need a relay harness.
Old Mar 8, 2011 | 10:30 AM
MattB07TL's Avatar
Is that what you had to do ? you don't think I could just put a 20 or 30 amp fuse in and be ok?
Old Mar 8, 2011 | 10:32 AM
no, this is not what i have done. as I dont have lower fogs.
But it is a common fix to add a relay to the HID bulbs in your fogs.
this way, you're not putting in a larger fuse
Old Mar 8, 2011 | 10:53 AM
MattB07TL's Avatar
Easy enough, Guess Ill order me up a relay harness then. Thanks
Old Mar 8, 2011 | 10:59 AM
try out DDMtuning.com
Old Mar 8, 2011 | 06:20 PM
dano4o8's Avatar
i just have a ballast hooked up to each fog and they've been running fine so far. o_O
Old Mar 8, 2011 | 08:27 PM
dwb993's Avatar
Always use a harness for HIDs. Better safe than sorry. $15 is not a lot to pay for the peace of mind. With that said, you can usually get away with a 15A fuse in a harness---the wiring is thick enough to handle the power.
Remember, fuses protect your wiring, not your devices. You always want the lowest number rating possible without it blowing.
08KBP_VA
Oct 22, 2019 01:55 PM
Jul 16, 2017 07:33 AM
mshipon
2G CL Problems & Fixes
Sep 28, 2015 12:14 PM
h22lude
Sep 27, 2015 06:22 PM
