how to get stripped bolt off door panel?
Old Oct 8, 2009 | 10:52 PM
BlacuraTL-S's Avatar
NBP REPRESENT
Question how to get stripped bolt off door panel?
I did 3 of my 4 doors with the moleskin but my passenger front door, the screw near the door latch that has the rubber circle pad around it just keeps turning and wont come out...
Whats the best way to get it off without doing any damage?(im not good with out of the box tool shit..lol)
and after i get it out, how to fix it so it will work properly?
thanks
Old Oct 8, 2009 | 11:18 PM
princelybug's Avatar
LIST/RAMEN/WING MAHSTA 짱
That bolt/screw gets screwed up all the time. You should go to the stealer and just buy a new one. It's only a couple of bucks.
Try to take the rubber stopper out, and get a set of vice grips around the head of the bolt and unscrew it. If that doesn't work, try and get a real small drill bit, and drill through the middle of the stripped bolt. Once it bites, unscrew the bit via some pliers.
Hope it helps.
Old Oct 9, 2009 | 07:31 AM
LoveMyTL-S's Avatar
This happened to my drivers side door while doing the same (moleskin) install. What I did was take some very skinny needle nose pliers, slide it into the back of the plastic door panel and grab the screw housing to keep it from spinning. Then unscrew it. Just be careful not to scratch the door panel. It's a pain, I know.
Old Oct 9, 2009 | 11:47 AM
NBP REPRESENT
ill try this and hopefully it works...
thanks!
Old Oct 9, 2009 | 01:12 PM
94eg!'s Avatar
#1 Super Guy!
Just hold the ring around the screw steady with your finger while gently turning the screw with a skinny driver. If it's just a plastic screw inside a plastic housing, that works fine. Had similar issues on my CRX. Try pushing against the ring to kinda jam it against the door panel to hold it steady...
Old Oct 13, 2009 | 03:44 PM
NBP REPRESENT
well it didnt work
i can get enough room behing the plastic part to put thin needle pliers to hold it...and holding the rubber part and trying to unscrew it didnt work either...
im prob going to take it to the dealer and blame them for something so they fix it under warranty...
Old Oct 13, 2009 | 03:48 PM
6spdtl-s's Avatar
Nismo TL yo!
I think i just ripped mine out??? i fogot what i did but do what you need to get it out save damaging the door. the screw is easily replaced.
IBankMouse
Jun 13, 2020 12:53 PM
95oRANGEcRUSH
Sep 25, 2015 12:50 PM
4drviper
Sep 23, 2015 07:42 PM
ROSSARONIE
Sep 22, 2015 11:46 AM
