how do you set automatic side mirror in reverse?
Old Jan 14, 2010 | 01:41 PM
eduardmc's Avatar
Acura TL 04, G37s 19"
when i bought the car the side mirror used to turn a little down when car set to R so i could see the curves. Now it does not do it anymore, how do i set it up, and can i set only one side to it. thanx
Old Jan 14, 2010 | 02:43 PM
tuanrich's Avatar
Put the adjust outside miror back to center position will activate this function again.
~Cheer~
Old Jan 14, 2010 | 02:44 PM
TonemanTLS's Avatar
LUV MY 2007 CBP TLS
your switch for the mirror has to be on the R or L for the mirrors to tilt down, if its in the middle they won't tilt down. Make sure it's on the R or L...
Old Jan 14, 2010 | 02:45 PM
eduardmc's Avatar
thanx, any way to assign only 1 mirror to be down or is not possible.
Old Jan 14, 2010 | 02:50 PM
05TLdcc's Avatar
Coal
Yes, if you want your driver mirror to go down you set it to that side, your left, and visa versa for the other mirror
hope that helped!
Old Jan 14, 2010 | 03:16 PM
Fulani has a TL's Avatar
~Cheer~
Wow, remove that "cheer" that you have, do homework before you make assumptions!
hope that helped!
You will only be able to choose either Drivers side or Passengers side, and do as 05TLdcc has stated and will work.
Old Jan 15, 2010 | 08:09 AM
eduardmc's Avatar
hope that helped!
thanx this worked, before the car used to do it in both mirror all the time (i'm not sure why) and i don't really know what i did but it doesn't do it anymore. But this work and thats what i needed, only one mirror to see the side curves, thanx again.
Old Jan 16, 2010 | 04:23 AM
djflex167's Avatar
both mirror at the same time, thats weird dude!! lol
Old Jan 18, 2010 | 08:03 PM
lumyeinjun's Avatar
i wish my car did both mirrors at the same time...
Old Jan 18, 2010 | 08:04 PM
princelybug's Avatar
LIST/RAMEN/WING MAHSTA 짱
+1.
Old Jun 22, 2010 | 04:36 PM
Roger555's Avatar
OCD
Ya my car was doing both mirrors then just the right now just the left. I didnt realize the position of the mirror level would have anything to do with this.
Old Jun 22, 2010 | 04:40 PM
killersrt's Avatar
The only way both mirrors will drop at the same time is if you have an aftermarket kit. I don't remember who sells it though. From the factory, like stated, only one mirror will drop down at a time
Old Jun 22, 2010 | 04:42 PM
Roger555's Avatar
OCD
No kit man car was bone stock when I got it, guaranteed both mirrors tilt some of the time but usually the right mirror, today is the left but the mirror adjustment knob is in the middle wtf??
Old Jun 22, 2010 | 04:49 PM
Slpr04UA6's Avatar
-------Tim-------
There is a kit out from KP Technologies, that allows both mirrors to tilt when put in reverse. The company makes the Window roll-up mod for our cars. That is odd that some people's cars can do both, while being stock. huh?
Old Nov 9, 2017 | 07:55 AM
gcarker's Avatar
When I first purchased my vehicle just over a year ago both mirrors adjusted down when in reverse. I didn't realize the inside mirror control was used for this feature. I'm going to try it later.
Old Jun 29, 2018 | 02:11 PM
Keith Allred's Avatar
7th Gear
My 2004 Acura TL has the automatic mirror adjustment that functions every time you put the car in reverse. It moves down to let you see the curb while you are backing up. It then moves back to its normal position while driving forward. If your car used to do that, you may want to see this post to fix it: https://acurazine.com/forums/3g-tl-p...-045-a-832020/
Old Jan 29, 2020 | 06:27 PM
Julia Bryan's Avatar
~Cheer~
Thanks, this worked on my sons 2002 Acura MDX
rockyboy
Aug 4, 2024 10:35 AM
space_boy
ILX
51
Aug 15, 2017 12:06 PM
sockr1
Oct 1, 2015 01:31 AM
hand123
Sep 10, 2015 09:27 AM
braveheart
Sep 7, 2015 08:12 AM
