Horn not working!
Old Dec 22, 2013 | 08:56 AM
AcctCanc11's Avatar
Horn not working!
So the horn in my 06 tl is not working by pressing the streeing wheel neither when pressing panic button. I dont know about the fuses or neither I have fhe manual. I would really appreciate the help.
Old Dec 22, 2013 | 09:46 AM
Vlad_Type_S's Avatar
Registered Bike Offender
Our cars have two tones, a high and a low. If they both went out at the same time, I would suspect the horn switch first, then the horns themselves. Plus it's much easier to test the switch than pulling off your bumper.
1) Perform a horn switch test. There's a thread somewhere on here with links to the PDF of the service manual that explains how to do this test. Unfortunately, I have no idea where. You basically pull off one of the connectors near the steering wheel and measure continuity.
2) If the horn switch works, remove the bumper and test the actual horns on your 12V battery. You just ground the plate and hook up the one pin to 12V.
My low tone went out so my car sounds like a sissy.
Edit: Found it! https://www.dropbox.com/sh/dsxqvazckcy8vnx/wlerJsyhTF Courtesy of member "thoiboi"
Old Dec 22, 2013 | 09:03 PM
AcctCanc11's Avatar
I dont think it is the switch because it doesnt work even with the panic button. I think it probably the horn or the relay.
Old Dec 23, 2013 | 01:46 PM
Test 'em out dude! Use that link I gave you for the service manual so you know what to do.
Old Jan 1, 2014 | 01:31 PM
AcctCanc11's Avatar
Took the horn out today to find out it had water in it. Any way to get it working?
Old Jan 1, 2014 | 02:02 PM
YeuEmMaiMai's Avatar
dry it out?
just buy a new one
Old Jan 1, 2014 | 03:12 PM
AcctCanc11's Avatar
Where can I find the exact same model of the horn? Because the horn I currently have has only one wire going through.
Old Jan 1, 2014 | 04:15 PM
Call acura and ask them what the part number for the horn is. I know on my CL all I have to do is take off the grille insert and the horn is easy to get to. that 1 wire provides power as the chassis is ground so you do not need a return wire...
mada51589
Jan 9, 2025 04:40 PM
spidermankb
Mar 5, 2019 11:34 AM
acurajj
Sep 19, 2015 03:47 PM
Luis J. Rodriguez
Sep 12, 2015 10:00 PM
ahsm
Sep 9, 2015 08:35 AM
