Hood Strut Question.
Old Nov 22, 2013 | 01:27 PM
VisualEchos's Avatar
Andrew
Forgive me, I just need clarification.
My 2007 TL's hood struts are now dead, and the replacement number I'm coming up with is Sachs #SG326009. I have found '04, '05 & '06 owners use this, but wonder if it's the same with the 2007. Calling Autozone, they say the Sachs number for the 2007 is SG365001, and they can't get it.
Any clarification?
Old Nov 22, 2013 | 03:10 PM
Turbonut's Avatar
Rock Auto (2006/2008):
SACHS Part # SG365001 HOOD LIFT $13.26
Old Nov 22, 2013 | 03:20 PM
Andrew
Thanks man, guess I'll just order from them. Appreciate the response!
Old Nov 23, 2013 | 02:42 AM
Alexns05's Avatar
Why does Acura list this as 2 separate parts but on other websites it has this as a single part for my 2004?
Old Nov 23, 2013 | 03:14 AM
paperboy42190's Avatar
^no reason. just order it
Old Nov 23, 2013 | 07:29 AM
Andrew
I've heard about the 2 part # thing, apparently there is no reason for it at all.
Old Nov 25, 2013 | 10:28 AM
flyromeo3's Avatar
get strongarm hood lifts. They're much beefer the OEM
Amazon.com: StrongArm 6351 Acura TL 2004-05 Hood Lift Support, Pack of 1: Automotive Amazon.com: StrongArm 6351 Acura TL 2004-05 Hood Lift Support, Pack of 1: Automotive
Old Nov 25, 2013 | 11:46 PM
Alexns05's Avatar
Yea they have them listed as different prices and different parts numbers, but the parts diagram points to the same part. Haha oh well
Old Nov 26, 2013 | 08:24 AM
carz0159's Avatar
Ya, mine went as well, best $50 I spent for both...I ended up needing to hold the hood up much more...and the shovel without a head just wasnt cutting it anymore.
Old Nov 29, 2013 | 09:34 AM
trugem's Avatar
mine suddenly stopped working as well... I wonder if it has something to do with the cold temperature? may sound crazy but they worked fine last week when it was 80 outside!
Old Nov 29, 2013 | 10:17 AM
erdoc48's Avatar
06 Anthracite TL
I assume they're gas as well as hydraulic struts. When it's cold, gas contracts and has less ability to extend the strut. I've noticed this on mine in the winter in the past few years. The hood won't fall, but it needs a little assistance to be pushed up. As long as the weight of the hood doesn't exceed the ability of the strut to hold it up, your struts are likely fine.
Old Nov 29, 2013 | 11:02 AM
pohljm's Avatar
I think i paid $16 for one and thats all I needed
Old Nov 30, 2013 | 11:54 AM
eastcoastguy's Avatar
I have had good experiances with rockauto so I think you should be good ordering from them as well
Old Nov 30, 2013 | 06:39 PM
LaCostaRacer's Avatar
I got mine at OReilly and they are Sacks. The OEM struts lasted 6 years and that's not a bad life if you consider the environment these struts live in.
I bought two struts but found that just replacing one was enough to keep the hood up. It's much easier closing the hood too- I often thought I was going to bend the hood with the level of force needed to close it when the car was new. I'll keep the extra strut and replace the other side in a couple of years.
Old Dec 1, 2013 | 01:38 PM
4drviper's Avatar
another happy vote for rockauto.
Old Dec 2, 2013 | 09:20 AM
Bearcat94's Avatar
AZ Community Team
Got mine at Rockauto too. Super easy to replace. Beats getting whacked on the back of the head by your hood, I can tell you that.
Old Dec 5, 2013 | 10:47 PM
Andrew
Yup, got them from rockauto, work perfectly, thanks guys!
Old Dec 6, 2013 | 10:49 AM
speaking from experience ehh?
It's definitely a frequently overlooked part until it drops on you while working on your car.
Old Dec 8, 2013 | 01:07 AM
Alexns05's Avatar
Thanks for the info guys! I just ordered 2 hood struts from rockauto. This will actually be my very first DIY so I'm kinda excited. I know it's lame because they're so easy to install but I've never done anything before so it's a start.
On a side note. Does anyone know what this ground wire could be for? It's taped to my hood strut. I'm thinking it might be for an automatic starter? The dealer never gave me the fob for the starter but I'm under the impression that I have one because there's a sticker under the hood.
Old Dec 8, 2013 | 01:09 AM
Alexns05's Avatar
sorry here's the picture
Old Dec 19, 2013 | 08:24 PM
Bearcat94's Avatar
AZ Community Team
Whatever it is, it's not stock. So, yeah, an add-on remote starter would fit the bill.
Old Dec 20, 2013 | 06:15 PM
Vlad_Type_S's Avatar
Registered Bike Offender
This reminds me of the time my drunk friend tried lighting his cigarette on a catalytic converter and dropped the hood on his head. And we laughed and laughed.....
Old Dec 26, 2013 | 11:37 PM
ThugLife07's Avatar
Where'd you search under? I tried searching through the parts catalog and I couldn't find anything. i even searched by the part # as well and nothing came up.
Old Dec 27, 2013 | 12:12 AM
Alexns05's Avatar
Well it depends what site you're using. But if you go to rockauto.com it walks you through the steps. Just click Acura-Year of Car- TL- Body/Exterior-Lift Support
Then pick whichever option you want. My car is an 04 so I picked the SACHS. Sachs/Stabilus is the OEM part for the car but I'm sure all will work fine.
Old Dec 27, 2013 | 01:48 AM
YeuEmMaiMai's Avatar
lift hood, hold it for a few seconds and the struts should catch up. my 2002 CLS is like this when it is cold.
Sometimes 2 different part numbers = 2 different manufacturers or a revision for some odd reason
Old Dec 28, 2013 | 03:00 PM
ThugLife07's Avatar
Same for both sides? It doesn't give me an option to specify which. Or would I be able to do with just one? Shipping is same regardless, so I'm thinking if I should just get both...?
Old Dec 28, 2013 | 05:10 PM
DMZ's Avatar
DMZ
Head a da Family
They're cheap enough to buy both. Buy the pair and be done..
Old Dec 28, 2013 | 06:30 PM
Alexns05's Avatar
Yea it's the same for both sides. I'd definitely get two, because you probably don't know which one isn't working, if its only one. I'd assume both of them probably need changed though.
Old Dec 29, 2013 | 06:11 PM
trayner76's Avatar
I got my struts from acurapartssource via eBay for $54 for both. This is an Acura Dealer in Cali so all the parts are OEM. My local dealer in NC was selling them for $60 each!
Check em out at http://stores.ebay.com/acurapartssource/
Old Dec 29, 2013 | 10:00 PM
ThugLife07's Avatar
Just placed my order for both. Thanks a lot for your help!
Old Dec 30, 2013 | 04:50 AM
Alexns05's Avatar
The OEM brand is SACHS/Stabilus. They are about $15 each on RockAuto website. The dealer website might charge you $25 for one that says HONDA, but it's SACHS.
No problem. I'm sure you can figure out how to put them on, but if not you just get a flathead and pull out the metal clips then the strut comes off. It literally takes a minute or two. Took a bit longer for me because I was in the dark garage with a flashlight and nobody/nothing to help me hold up the hood. Haha
Old Dec 30, 2013 | 05:02 PM
leo221's Avatar
I got a pair of strong arm 6351 at Amazon. Only time will tell if they are better or worse than OEM.
Old Dec 30, 2013 | 06:26 PM
DuoDSG's Avatar
Make it so
Thumbs up
I replaced my hood struts last spring with the Stabilus (same as SACHS, apparently, from what I'm reading in this thread) and got them for $14.
Originally I was going to purchase them from RockAuto, but I happened to find that the O'Reilly Auto Parts store nearby had them for a bit cheaper, plus I didn't have to pay shipping. Bought a pair, I was set to go.
I know it's not usual policy for stores to do that, but it was just my luck that they did. If you happen to be out and about, and especially if O'Reilly parts is nearby, it's worth seeing what their price is for the pair.
I hate auto parts stores in general because they tend to sell really sub-par brands, but this time I lucked out. Good luck!
Old Dec 30, 2013 | 11:31 PM
Alexns05's Avatar
I love how the guy said he already bought the parts and people are still commenting telling him where he should look to buy the part...? I guess some people just read the threat title and don't read what people actually write.
Old Jan 8, 2014 | 12:19 AM
ThugLife07's Avatar
Sooooo lame. RockAuto just contacted me saying they're out of stock and not knowing when they'll be in stock again. Dammit!!!
Old Jan 8, 2014 | 01:33 PM
Alexns05's Avatar
Damn, that sucks. But just copy the part number and order them from somewhere else. Might be a little more expensive but they should have them everywhere. They might even have them at a local Autozone or something for decent price
Old Jan 8, 2014 | 08:21 PM
flint's Avatar
Try strongarms or AMS
Jul 16, 2017 07:33 AM
lanechanger
Oct 13, 2015 10:56 AM
Bielikb96
Sep 28, 2015 10:45 AM
mellsonnj
Sep 24, 2015 04:42 PM
