helpppp!!!!!
Old Oct 31, 2010 | 09:24 PM
Resse4x's Avatar
05 6speed
helpppp!!!!!
ok the problem i have is the worst brought it to the dealer they dont know wat to do. when i drive and im coastin and go to accelarate it jerks a lil bit then i was on the highway and the vsa light came on and i could not accerlarate at all had to turn the car off then it was okay any ideas on wat it is
Old Oct 31, 2010 | 09:30 PM
Need more details.
what year is the car?
how many miles on the car?
have you checked the oil level? making sure its not low.
at what speeds does this happen?
what RPM's does this happen?
Old Oct 31, 2010 | 09:32 PM
WRXtranceformed's Avatar
#ForcedInductionFamily
It sounds like your car went into limp mode. You probably threw a CEL also. If so, did the dealer pull it for you? Let us know if you find out which code it is.
Old Oct 31, 2010 | 09:44 PM
Resse4x's Avatar
05 6speed
2005 6sp m/t 84k its jersks at any speed but the vsa lights comes on the highway only at speeds of maybe 70 or better and the code said tps
Old Oct 31, 2010 | 09:54 PM
Search "app Sensor"
https://acurazine.com/forums/3g-tl-problems-fixes-114/help-my-car-limp-mode-793127/
https://acurazine.com/forums/3g-tl-problems-fixes-114/diy-app-sensor-730958/
Old Oct 31, 2010 | 09:55 PM
If you do an exact search for whatever the code was on this forum (code = PXXXX) you will probably find a good place to start looking for the answer to your question.
Old Oct 31, 2010 | 10:46 PM
AckTL05's Avatar
Former Sponsor
Its the APP sensor. Our cars are dual sensors so when they go out of alignment (some wiggle room) it throws the car into limp mode. APP sensor is (Accelerator Pedal Position). They are $130 at the dealer and its located to the left side of the strut tower bar. This is a reason on the single sensor cars (priuses) run out of control...
teeeejaay
Mar 5, 2014 02:04 AM
Dmhowl
2G CL Photograph Gallery
Dec 11, 2012 10:17 PM
Rsoetidjo
26
Apr 1, 2012 11:17 AM
mahfuzzz
Dec 27, 2011 01:52 PM
