Help! VSA, CEL, ! Warning light on, and stuck in limp mode
Old Mar 23, 2018 | 10:50 AM
Kgren07's Avatar
3rd Gear
Hey all. I have an 06 vase with 107,000 miles on it. A few weeks ago I drove to work just fine, came out to leave and car was in limp mode. It was found that I blew the DBW fuse. I believe this happened due to water dripping on my fuse box because of a clogged sunroof drain tube. I limped it home, replaced the blown fuse, fixed the drain tube, and now the car is still stuck in limp mode, VSA light is on, CEL is on, and the ! Warning light is on. I have rechecked all my fuses in the whole car, unhooked the master cylinder wiring to rule that out, and my car is throwing codes for abs voltage, VSA voltage, and one other (sorry I forget what it was). I had my battery die a couple months ago and replaced it and didn’t have an issue until this happened. Any ideas where to start to get this fixed? Thanks!
Old Mar 23, 2018 | 10:58 AM
polobunny's Avatar
Registered Bunny
What are the codes?
Old Mar 23, 2018 | 11:21 AM
Kgren07's Avatar
3rd Gear
I don’t remember off the top of my head. I’m going to stop by the shop and get them off my mechanic on my way to work.
Old Mar 23, 2018 | 12:56 PM
Kgren07's Avatar
3rd Gear
61-1 - battery voltage low
83-1 - ecm relation fail
86-1 - CAN relation fail
112-1 - internal power source failure
Old Mar 24, 2018 | 10:52 PM
Xavier Castillo Lopez's Avatar
Acura tsx VSA light
I have a question about my 2009 Acura tsx. When ever I push and hold the VSA button for 3 secs the (!) Turns on insider a triangle and it stays on. If I hold the VSA button again for 3 secs it turns off. My question is, is the triangle light supposed to stay on while I have the VSA on or not and how do I know if the VSA is working properly on my car. Let me know asap. Thank you
gwai1o
Mar 30, 2012 09:48 PM
MGD166
Integra
Apr 21, 2011 11:35 AM
kevinballer08
Apr 19, 2011 09:45 PM
bdelanoy
Nov 19, 2009 02:49 PM
Comet2404
Sep 3, 2007 03:39 PM
