Help. Something wrong with gas?
Old Apr 6, 2011 | 07:23 PM
Phambam12's Avatar
Phmbm12
I just filled up a full tank. My gauge says i have 1/4 tank and it reads zero on the range. whats up with that??
Uploaded with ImageShack.us
Old Apr 6, 2011 | 07:39 PM
VQPower37's Avatar
what does the mid say as mpg?
Old Apr 6, 2011 | 07:40 PM
Phambam12's Avatar
Phmbm12
24mpg
Old Apr 6, 2011 | 09:06 PM
cpm06wdptl's Avatar
Sounds like it could be a sending unit issue. Were you at 1/4 tank when you filled up?
Old Apr 6, 2011 | 09:21 PM
Phambam12's Avatar
Phmbm12
i was on empty. it gradually went up to full tank over 30 minutes of driving but the range still says zero
Old Apr 7, 2011 | 10:35 PM
ntmera's Avatar
did you fill it with water?
Old Apr 7, 2011 | 11:18 PM
csmeance's Avatar
I'm guessing that the fuel level sensor is going a bit haywire. Have you ever run fuel cleaner through the gas tank? Do you use premium fuel?
BMW has been having a very similar problem and the issue is that something in the fuel coats the sensor over time, and using a fuel cleaner such as Redline SC-1, BMW Fuel Cleaner or Techron will clean most of it off and fix it. -> This was issued to dealers after quite a few decided to replace the whole darn fuel sending unit that cost BMW upwards of 2K in warranty work per car!
Old Apr 7, 2011 | 11:39 PM
kingkong_dav's Avatar
KingKong_Dav
inside your fuel thank have a floater, it is damage or is worn. replace with new unit as directed.
xsilverhawkx
Oct 5, 2015 11:00 AM
MilanoRedDashR
Oct 2, 2015 10:49 AM
Skirmich
Oct 1, 2015 12:59 PM
San Yasin
Sep 29, 2015 10:52 AM
