HELP! Problems with acceleration (cant rev the engine)..
Old May 21, 2009 | 05:35 PM
timb24's Avatar
once you go black....
Angry HELP! Problems with acceleration (cant rev the engine)..
So im driving on the highway today and all of the sudden while accelerating, the car starts jumping like its hitting a rev limiter. When i slowed down and the rpm's were below 2000 it was OK, but as soon as I try to accelerate above 2100 rpm's it would have this same problem (it was exactly like when I have VSA on in the snow, and when the tires spin, then the rev limiter kicks in).
This only happens when im in gear (I have 6 speed MT), when im not in gear I can rev the engince as much as I want and it is fine. Could this be a problem with the transmission? Has anyone else had this problem? I'm stumped....
Old May 21, 2009 | 08:20 PM
Hi speed's Avatar
runnin a little boost
Sounds like limp mode to me. I know when I ran out of gas in many cars, the car would stop accelerating but if taken out of gear would rev. Did you down shift and redline the engine before this?
Old May 21, 2009 | 08:56 PM
timb24's Avatar
No I didnt. So you dont think this a clutch issue (slipping)? How would you recommend i fix this, because it continues to be an issue.
Old May 21, 2009 | 09:59 PM
Will Y.'s Avatar
Registered but harmless
Any malfunction lights?
Possibly the accelerator pedal position sensor-- someone else recently had a thread on it, but this was the closest I could find: https://acurazine.com/forums/showthr...osition+sensor
Here it is: https://acurazine.com/forums/3g-tl-problems-fixes-114/acceleration-failure-while-driving-726039/.
Old May 21, 2009 | 10:11 PM
timb24's Avatar
Here it is: https://acurazine.com/forums/showthread.php?t=726039.
Yea that sounds very similar to my problem, however there havent been any malfunction lights at all. Also, I can still drive the car at low RPM's. Its only when i try to accelerate past 2100 (or so) RPM's that the acceleration starts "shuddering"
Old May 21, 2009 | 11:52 PM
Tumbleweed13's Avatar
Does speed or throttle position matter? Can you get the vehicle up to 40-50mph with lite throttle, or will it not accelerate at all?
Old May 22, 2009 | 08:07 AM
timb24's Avatar
Yes, I can get it up to any speed I want with very light throttle. Like I said, when i try to push it past 2100 rpm's is when I have the issue.
Old May 22, 2009 | 09:15 AM
You said it acts like it is hitting the rev limiter, but do the rpms jump while it is happing? If so it does sound like your clutch is slipping. If not, it sound like the differential or even a axel is bad. to test your axel raise the front end off the ground with the car off put the car into gear, have someone hold 1 wheel to keep it from spinning, and you take the other wheel and see if you can spin it. you should not be able to.
carz0159
Sep 20, 2015 06:11 PM
Sep 14, 2015 03:16 PM
Mike Bertram
Sep 10, 2015 09:27 AM
ninersfgiantsfan
Sep 9, 2015 01:14 PM
Phambam12
Sep 6, 2015 06:57 PM
