Help ! Power steering
Old Jan 11, 2012 | 11:02 AM
S.Blazes's Avatar
yayayay..
i know change the inlet o-ring from the reservoir.
i did that the other day but i still seem to be having a weird noise coming from my pump. the noise is substantially better now compared to before i replaced the o-ring, but im still having a weird kind of gurgle sound being emitted.
im pretty sure the pump is fine, i still have full steering with no resistance.
any ideas acurazine?????
Old Jan 11, 2012 | 11:58 PM
S.Blazes's Avatar
any one know if there is another part listed on the tsb?
the links dont seem to be working for me
Old Jan 12, 2012 | 12:13 AM
Bearcat94's Avatar
AZ Community Team
If you're getting air in the system, it may be coming from a seal other than the inlet o-ring. GuitarPlayer16 (iirc) did a good DIY on rebuilding the PS pump which replaces all the rubber seals and o-rings. There is a link on this page: https://acurazine.com/forums/3g-tl-2004-2008-93/3g-tl-garage-faq-3g-tl-newbies-553554/
As far as the TSB access, you have to follow the access instructions Ron A posted before the TSB links will work. Go to the link below for the instructions and the TSB links.
https://acurazine.com/forums/3g-tl-2004-2008-93/3g-tl-technical-service-bulletins-tsbs-3g-garage-j-016-a-613659/
Old Jan 12, 2012 | 06:24 PM
S.Blazes's Avatar
Thank you sir!
Time for a rebuild !
Old Jan 12, 2012 | 08:08 PM
swoosh's Avatar
takin care of Business in
start by doing cheaper things....
replace the o-ring....hope that will take care of the noise....also do a PS flush....
both the links here:
https://acurazine.com/forums/3g-tl-2004-2008-93/104-diy-power-steering-fluid-flush-761094/
https://acurazine.com/forums/car-parts-sale-361/anybody-got-cl-type-s-rims-sale-trade-173686/
https://acurazine.com/forums/3g-tl-problems-fixes-114/diy-105-power-steering-whine-fix-754586/
Old Jan 12, 2012 | 11:55 PM
S.Blazes's Avatar
https://acurazine.com/forums/showthread.php?t=761094
https://acurazine.com/forums/showthread.php?t=173686
https://acurazine.com/forums/showthread.php?t=754586
i already replaced the inlet o-ring about 3-4 days ago.
i did not try flushing my system though. i mite do this as well.
i wouldnt mind rebuilding all the seals inside the pump for my own personal satisfaction. lol
Old Jan 13, 2012 | 12:09 AM
swoosh's Avatar
^^^ i would try the flush first....i am guessing there might be some air in the system....
with the car on, check if you see bubbles in the PS reservoir....if you do, then do the rebuilt before you do a flush....if no bubbles, then flush first....
Old Jan 13, 2012 | 01:09 AM
S.Blazes's Avatar
thank u sir.
will flush tomorrow pending weather ( canadian winter )
Old Jan 13, 2012 | 12:39 PM
swoosh's Avatar
^^^ hahahaha....yeah i know what you mean....
am in Kansas and the mods are waiting for the weather to get warmer....
swoosh's Avatar
Old Jan 14, 2012 | 01:38 AM
S.Blazes's Avatar
LOL yah man
i woke up to like 5 cm of snow lol
but yah i went n checked the p.s reservoir today and they are still bubbles being formed.
even though i changed the black o ring to the orange inside the inlet to the power steering pump.
so i guess im gonna be doing a rebuild this weekend lol
would that stop air from entering the system?
Old Jan 14, 2012 | 10:38 AM
swoosh's Avatar
^^^ most prolly....
air in the system means there is a leak somewhere.....u got the TSB done recently right ? just take her back to the dealership and explain your disappointment....see what they can do for you.....
if they dont do shizzz then do the rebuilt urself....
Old Jan 14, 2012 | 01:01 PM
S.Blazes's Avatar
lol well i didnt really get the tsb taken care of...
i replaced the inlet (#13) o ring myself.
is there any other items other then that single inlet o ring i should consider replacing before i rebuild the pump?
i have a 07 type s 6speed 77760 miles
Old Jan 14, 2012 | 07:04 PM
swoosh's Avatar
^^^ bah my bad....i should have asked you this before....
some models were called in for a TSB which was for the PS pipe insulation....make sure your car is not within the vins.....if it is, take it in and have them look into it....
Old Jan 14, 2012 | 08:32 PM
Bearcat94's Avatar
AZ Community Team
All '07 Type-S are excluded from that recall.
Old Jan 15, 2012 | 12:34 AM
swoosh's Avatar
^^^ Database updated
Old Jan 17, 2012 | 12:03 AM
S.Blazes's Avatar
ohhh....
so how can i pin point the air leak?
Old Jan 17, 2012 | 01:16 AM
swoosh's Avatar
I would suggest check the 2 hoses (return/supply) in the reservoir....if they are nice and snug, i suggest a PS pump rebuild...
Old Jan 17, 2012 | 07:37 AM
S.Blazes's Avatar
okay !
thank you sir !
Old Jan 17, 2012 | 12:19 PM
swoosh's Avatar
^^^ no problem buddy....keep posting them updates
Acura604
20
Aug 5, 2017 12:55 AM
Jul 16, 2017 07:33 AM
Euro4gen
Dec 12, 2015 03:14 AM
95oRANGEcRUSH
Sep 25, 2015 12:50 PM
