'06 Manual Transmission Fluid Locations
I am going to try to check the fluids on my friends 2006 TL 6MT. I did searches and found out to check all the fluids as his clutch pedal goes all the way to the floor and hardly engages gear, and also doesn't return back to the original postition. I remember reading the secondary slave valve I believe to be low on fluid sometimes but is covered by plastic so you can not check the ground to see if it is leaking.
Can anyone tell me the location of all the fluids where I should be checking or have a diagram?
Thanks.
Thanks.
It's the small tank on the drivers side firewall under the hood.
Look in this thread. Scroll down and you'll see a pic of the tank.
https://acurazine.com/forums/3g-tl-2004-2008-93/clutch-pedal-master-cylinder-slave-cylinder-replacement-3g-garage-094-a-644160/
Page 12-9
Page 12-9
mada51589
Jan 9, 2025 04:40 PM
BlkTxAcuraTypeS
Oct 18, 2015 08:05 PM
Mike Bertram
Sep 10, 2015 09:27 AM
HeloDown
Sep 8, 2015 06:51 PM
