help! p2610 code
help! p2610 code
before this code came up my car was jerking a losing power. got it towed home and once i got home i attempted to start my car but once i put my key on the acc position without even cranking the key my car started on its own. on the mini display a message came up saying "check starting system" after so many tries trying to figure out why it was doing that, my car wont start no more. no crank nothing. cel came up and got the code p2610. i checked the starter and ignition switch everything came up good. i jumped the starter and it cranked but wont turn over so there has to be a something going on with that code not letting my car start. also i realized that i was able to shift from park to any other gear without pressing down brake so im thinking i might have a bad neutral safety switch but i dont think that would cut off fuel? idk i could be wrong.. any advice would help. just trying to see if i did everything possible before taking it to the dealer. bty its a 08 TL base
it means its not detecting the "engine off timer" I havnt had this problem but maybe someone else has who will chyme in. Start by checking all your fuses cause its quick easy was to diagnose issues. Dont get your hopes up but I have come across real scary and stressful situations where all it was is a broken fuse.
Would you or anyone would know if I can buy a new ecm and can program for my car because my dealership don't know if they can program it I buy a new one.... what kind of shit is that lol fml
trying get large profit from your repair, I bring my own part and having the Acura dealer doing the work and paying for labor.
