Help me read the ATF dipstick
Old Sep 24, 2010 | 01:02 AM
gotkilled's Avatar
NBP is a pain...
I did the reading after I drove the car on the freeway for about 15 minutes. Reading was taken within 90 seconds of turning off the car.
I apologize in advance for the bad nighttime camera phone pics
side without any atf
side with splotchy atf. looks overfilled??
Old Sep 24, 2010 | 06:22 AM
myblack04tl's Avatar
There needs to be fluid on both sides of the stick. Usually when you see it on one side only it's because it has rubbed on fluid somewhere sliding down the tube.
If you stuck your finger in oil would you only see it on one side of your finger?
Old Sep 24, 2010 | 06:57 AM
Turbonut's Avatar
You're not alone:
https://acurazine.com/forums/3g-tl-2004-2008-93/weird-atf-level-reading-even-after-car-run-787563/
If the fluid level is correct, you'll see fluid on each side of the dipstick, got to be there, but may have been inadvertently wiped when stick removed. Try it numerous times at different intervals.
Old Sep 25, 2010 | 12:47 AM
gotkilled's Avatar
NBP is a pain...
thanks turbonut. i was actually the one that started the thread lol
If i check the dipstick while the car is running, the dipstick will have fluid covered on both sides and will be about two inches above the uppermost indicator mark.
MrHeeltoe
20
Feb 23, 2023 01:54 PM
Jimmy_D
Oct 7, 2015 11:52 PM
MrHeeltoe
Sep 29, 2015 10:43 PM
hashbrown
Sep 29, 2015 12:13 PM
MrHeeltoe
Sep 28, 2015 05:43 PM
