Help me identify this warble noise
Old Apr 27, 2012 | 09:37 PM
oneglory's Avatar
I tried searching but it's hard to find references to 'sounds'. One man's warble is another man's burble.
Anyway, any ideas?:
Old Apr 28, 2012 | 12:12 AM
alexb92's Avatar
Check the heatshield right above the j-pipe, next to the axle and make sure its not loose.
Old Apr 28, 2012 | 05:57 AM
Turbonut's Avatar
Remove the serpentine belt, start the car to see if noise dissipates, if so check all the pulleys, especially the idler pulley. If noise still persists, possible water pump or timing belt tensioner.
Old Apr 28, 2012 | 08:34 AM
oneglory's Avatar
I just had the timing belt/tensioner and waterpump replaced at hamilton honda about a month ago..honestly i can't remember if the noise was there prior or not. Perhaps I should ask them about it.
I'll check the idler pulley..seems logical.
Old Apr 28, 2012 | 09:23 AM
Turbonut's Avatar
I would think that if the noise were present at the time of service they would have mentioned it to you, but as stated, just remove the serpentine belt start the car and see if noise is present. I believe there should be no noise when belt removed.........................but in my lifetime I've been wrong before sorry to say, not often, but it happens.
04WDPSeDaN's Avatar
iWhine S/C 6MT TL
Belt tensioner for the drive belt, not the t-belt one.
MrHeeltoe
20
Feb 23, 2023 01:54 PM
SexyRL
4G TL Problems & Fixes
Aug 19, 2016 10:03 PM
xsilverhawkx
Oct 5, 2015 11:00 AM
MrHeeltoe
Sep 29, 2015 10:43 PM
MrHeeltoe
Sep 28, 2015 05:43 PM
