'04 TL (05 Engine Swap) = acceleration problem
Old Mar 27, 2012 | 09:53 PM
nick1acura04's Avatar
Exclamation '04 TL (05 Engine Swap) = acceleration problem
I have an 04 TL and recently swapped my engine with an 05 TL engine because of previous owner overheated the engine. Long story short what happened was i put the engine in and it was working great. About a week ago i noticed that my car was speeding up right. A guy talked to me about resetting my ECU and i tried that and found out my VTEC was not working and when i reset my ECU it worked. Now I have a problem at around 5300 rpm's. The problem is that is when i speed up and hit that rpm range it feel like my VTEC stops because it doesnt speed up fast at that rpm like it should. When i first did the swap I ran it nice and easy and gradually pushed it little by little and one day I took it out to the highway and i hit 140 like nothing and now with the problem occcuring I can barely hit 120. and when i do it speeds up 1mph every like 3 seconds its so slow and my mechanic cannot figure out why? any ideas
Old Mar 27, 2012 | 10:22 PM
kingkong_dav's Avatar
KingKong_Dav
at or mt?
Old Mar 27, 2012 | 10:52 PM
Mt
Old Mar 27, 2012 | 10:57 PM
KingKong_Dav
how did the mechanic do the ecu reset?
Old Mar 28, 2012 | 07:12 AM
I reset the edu by the key way not by unplugging ur battery
Old Apr 28, 2012 | 04:13 PM
Kajan_8's Avatar
2011 SHAWD
how good is the new motor? did you check the valves?
justin7779
Dec 25, 2015 10:33 PM
carz0159
Sep 20, 2015 06:11 PM
Mike Bertram
Sep 10, 2015 09:27 AM
HeloDown
Sep 8, 2015 06:51 PM
NSolace
Sep 3, 2015 08:14 PM
