HELP!! Keyless entry and Domes not working!!
Old Jan 16, 2012 | 11:10 PM
conversehtnut's Avatar
Don't Mess With My Type-S
Exclamation HELP!! Keyless entry and Domes not working!!
Sooooooo, I'm a bit stuck, and flustered, and frustrated as all hell. I know its long but I'm really stuck.
I was trying to finish my install of the Lighted door sills that I had received earlier from Supercomputer. Last week I installed the driver side. Both sills work perfectly on the door switch as they are supposed to. Today I went to try and fix the passenger side install. I had put them in the same time as the driver side but they were not lighting up at all.
I was following the wiring instructions from this thread (https://acurazine.com/forums/3g-tl-2004-2008-93/diy-illuminated-side-sills-led-overlays-supercomputers-821684/). When I had first installed the passenger side I had the power lead attached to the grey wire w/ blue stripe and they would not work. Using the above thread instructions I found the white w/ red stripe wire and went to tap into that. First I had to cut the red that I had previously attached since I could not get the tap off.
After I finished wiring I noticed that the dome lights and courtesy lights were not on. I shut all the doors and tried to lock and unlock with the remote but that wouldnt work either. I got the second remote out of my house thinking the battery was dead but that one didn't work either. I disassembled the passenger side wiring I had just done but no luck. I went over to the fuse box and noticed that the interior light fuse was blown. I switched it with a good fuse and the courtesy lights came back on, but not the domes (and the remote still doesn't work).
The kicker is that the dome lights work on the switch if I want to turn them on manually, they just don't come on when the doors are open.
Does anyone know what I can do? I am going to pull all the fuses and see if any others are blown but I am at a loss on which ones to pull. I also am trying not to take this to the dealer since I cannot afford to be without a car. At this point I don't even care about having the sills, I just want the car to work like it's supposed to again.
Old Jan 17, 2012 | 09:14 AM
and to add to my frustration, today I noticed that the HFL and mirrors arent working
mada51589
Jan 9, 2025 04:40 PM
tman570
Jun 11, 2019 07:56 AM
acurajj
Sep 19, 2015 03:47 PM
ahsm
Sep 9, 2015 08:35 AM
pesobreeze
1G RL (1996-2004)
Sep 3, 2015 12:26 PM
