help: cracked rim
Old Jun 23, 2010 | 12:58 PM
cbass's Avatar
help: cracked rim
i woke up this morning to find my tire flat. i tried to air it and no luck, i checked the rim and found the inner lip to be cracked!
i was looking around and considering just ordering another rim that most likely isnt oem since they are half the price of what acura charges. is this a good idea? anyone order from any particular sites?
any help appreciated.
Old Jun 23, 2010 | 01:46 PM
BG74's Avatar
Check eBay for a used one? Or, if you're under warranty, maybe your dealer will help you out?
Old Jun 23, 2010 | 04:30 PM
cbass's Avatar
does any have the exact dimensions of the stock rims?
offset, bolt pattern, diameter, etc
Old Jun 23, 2010 | 05:40 PM
csmeance's Avatar
17" x 8" 114.3 x 5 offset is +45
Check out wheelsandcaps.com, a lot of BMW guys go there for factory rims. Also check out the black market section and ebay.
Old Jun 23, 2010 | 09:48 PM
AMUA6's Avatar
ScoobyZINE
What is the styrofoam inside the wheel?
Old Jun 24, 2010 | 12:05 AM
cbass's Avatar
its the little tire changing kit the car comes with. the wheel is in my trunk at the moment
Old Jun 24, 2010 | 09:39 AM
DMZ's Avatar
DMZ
Head a da Family
Go to ebaY and search this item #:
130370452668
Old Jun 24, 2010 | 09:48 AM
AMUA6's Avatar
ScoobyZINE
Ohh ok. Makes sense. GL OP Also try some junkyards??
Old Jun 24, 2010 | 11:18 AM
cbass's Avatar
yea. it's going to be hard to find just a single rim. most likely going to order one. anyone ever use aftermarket stock looking rims?
Old Jun 24, 2010 | 11:31 AM
cbass's Avatar
any truth to this?
http://answers.yahoo.com/question/in...5045835AAARgux
Old Jun 24, 2010 | 12:39 PM
shadowkahn's Avatar
to which? The don't put the donut on the front wheel thing? Yeah, that's true. It's bad for the car. And the part about only using it to get to the tire place is pretty true too. You can probably get away with driving it for a few days, but the spare isn't designed to be a daily use tire.
Old Jun 24, 2010 | 02:08 PM
LoveMyTL-S's Avatar
There may be a place in your city that repairs rims.
http://www.mywheelrepair.com/wheel-r...FcRM5QodfnOn5g
http://www.autobodynearyou.com/ml2/?...818080F8071820
http://wefixwheels.com/texas/houston_tx/index.htm
http://www.nsxprime.com/FAQ/TireWhee...heelrepair.htm
http://www.wheeltechnologies.com/locations.asp
And here's a thread on Houston rim repairs:
https://acurazine.com/forums/1g-tsx-tires-wheels-suspension-130/rim-repair-houston-661496/
Old Jun 24, 2010 | 04:44 PM
cbass's Avatar
I found a set from an 06. should fit right?
Old Jun 25, 2010 | 10:20 AM
LoveMyTL-S's Avatar
Yes, it should fit. They used the same specs for all 3G TL's.
Old Jun 25, 2010 | 05:07 PM
cbass's Avatar
wow. i just found out that the trunk cant hold a actual spare tire, only a little donut. pretty inconvenient
Old Jun 26, 2010 | 08:28 AM
DMZ's Avatar
DMZ
Head a da Family
What would be inconvenient is if you had a full size spare in there and were left with no trunk space. That's why the donut.
Old Jun 26, 2010 | 03:28 PM
cbass's Avatar
yea, i guess there isnt enough room. but some cars have a spare and the trunk space
Old Jun 26, 2010 | 04:36 PM
badteddy's Avatar
this has happened to me as well and i told them to repair the rim because the guys i took it to said they would have it next day for me. i really didnt want to deal with having to find a used rim. it cost me $85
bluetl04
Aug 16, 2016 02:49 PM
kev87a
Nov 2, 2015 07:40 AM
Gout
Nov 2, 2015 12:22 AM
kev87a
Oct 18, 2015 02:03 AM
dirleton
20
Oct 16, 2015 01:48 PM
