Help-- Adjust Side mirror doesn't work
Old Feb 18, 2012 | 03:15 AM
baby904965's Avatar
When I try to adjust the side mirror it only down and right works. Normally if I back up it automatically gose down when the litlle switch is on the right mirror adjust place but it doesn't work either. Someone know what is the problem?
Thanks!!
Old Feb 18, 2012 | 10:46 AM
Will Y.'s Avatar
Registered but harmless
If the wiper fluid doesn't spray and auto-dim on the rear-view mirror also doesn't work(no green light on the mirror), then I believe it's fuse #20. A TSB addresses the problem by recommending replacement of the 7.5 amp fuse with a 10 amp fuse.
Welcome to AZ.
Old Feb 18, 2012 | 09:41 PM
jokerman826's Avatar
Jokerman
if it was a fuse, then how would he be able to move the mirror in certain directions and not others. Does the other mirror work properly. If not then my guess would be the switch. If the other mirror does wotk properly, then i would be guessing that the actuator for the mirror is bad.
Old Feb 18, 2012 | 10:01 PM
badbart's Avatar
Question
Welcome to AZ.
Ok, I just bought a TL last weekend, and I have this list of issues exactly. Can you get me more info on this TSB? Link to something or the name of the TSB so I can search it out? I also have random locks that work work. Sometimes the passenger side locks or unlocks, sometimes the drivers feels like locking... other times it doesn't. From many other threads, it sounds like that could be the actuator, or the fuse panel itself? Could the door locks also be related to this TSB?
Awesome user group here. Glad I found you all!
BB.
Old Feb 19, 2012 | 12:47 AM
Will Y.'s Avatar
Others had the problem with reduced operation of the mirrors as well as no wiper sprayer or auto-dim, and it was fuse #20, so it's the way the TL's minor controls were engineered.
Might as well check the fuse first, BTW, since it's cheaper and easier than buying a mirror switch or actuator.
The TSB is b05-033, which can be viewed at: Acura[world.com]/tsb/3gTL/b05-033.pdf <[remove the brackets for the http address-- AZ doesn't like competing sites].
I think the TSBs were renumbered or it was superseded later, as I can't find it on AZ's October 2005 TSB lists.
However, it sounds like you have a bad door lock actuator since the door locks are a separate issue.
Welcome to AZ too!
Old Feb 19, 2012 | 04:02 PM
Jokerman
Welcome to AZ too!
I see what you are saying even though it makes no sense, hopefully the OP comes back and lets us know.
Old Feb 20, 2012 | 01:10 PM
baby904965's Avatar
Problem Solved
Welcome to AZ.
Problem Solved!!! I checkd the wiper spray fuse and it did burnd. I just got it replaced all problems gone. Thanks all of you guys.
Old Feb 20, 2012 | 03:25 PM
Jokerman
good, glad a suggestion worked for you. I need to look at the electrical drawings for this damn car more to find out how things are wired up. Hope you stay around to build up your post numbers.
Old Feb 22, 2012 | 11:12 AM
badbart's Avatar
Welcome to AZ too!
This Fixed my issues as well. Also fixed the seat/mirror memory (hadn't noticed it not working yet... new to me car and all) Thanks for the help! Now... on to the door locks- and yes, first step is replacing the battery, it looks like it is crap. - but that is a topic for another thread.
Old Feb 22, 2012 | 11:36 AM
badbart's Avatar
How does one "Thank" another poster...
Old Feb 22, 2012 | 11:37 AM
badbart's Avatar
Never mind, just hit the "thanks" button......
Old Feb 22, 2012 | 12:18 PM
Will Y.'s Avatar
Glad everything is back to normal!
Old Dec 12, 2013 | 06:22 PM
Jon Mallory's Avatar
4th Gear
New I would find the solution here!! Now to check that #20 fuse!!
Old Dec 12, 2013 | 07:05 PM
coffeebowl's Avatar
awesome, just replaced mine.
AndrewS
19
Mar 14, 2024 06:59 PM
Feb 25, 2020 09:57 AM
space_boy
ILX
51
Aug 15, 2017 12:06 PM
Rocktman1
Oct 31, 2015 02:33 PM
acurajj
Sep 19, 2015 03:47 PM
