Heating Problems
Heating Problems
Last night the heat was working just fine. But, after my mom had taken the car all day only the drivers side heat works. when i set both sides to 80 degrees only the drivers side will blow hot air. While the Passenger side will blow really cold air. I have tried messing with the setting but nothing seems to be working.
Any advice?
Any advice?
For what it is worth and I am not too familiar as to what may resolve this bit, Do Not Blame Your Mom! LOL.. You may want to check into your dual climate control. I am a new TL owner and not really familiar with everything. I would recommend searching the forum before anything. I personally would look into the electrical schematics if you can find them. There is a possibility that some sensor or something in the climate control has malfunctioned. Once again, I am a NOOB and just purchased my first TL a month ago!
You might try sounding a little more grateful. I'm sure his intentions were not to annoy you.
That's weird. It almost had to be electrical since the water control valve had to be open for one side to get hot. Let us know if it does it again. My heat is starting to act up too.
maybe a vacuum leak on the doors that control the air flow to the vents? not sure if they are even vacuum controlled, but thats a common occurrence in many vehicles
i have a 08 tl-s and i have no heat on the drivers side, also when i put it in cold i hear clicking like if something was trying to open but its stuck? try to put it in cold and see if u hear the clicking???????
SidhuSaaB
05-30-2020 12:40 AM
detailersdomain
Wash & Wax
10-09-2015 10:13 PM
