Heating Problems
Old Oct 16, 2010 | 07:09 PM
Sandals's Avatar
Heating Problems
Last night the heat was working just fine. But, after my mom had taken the car all day only the drivers side heat works. when i set both sides to 80 degrees only the drivers side will blow hot air. While the Passenger side will blow really cold air. I have tried messing with the setting but nothing seems to be working.
Any advice?
Old Oct 17, 2010 | 01:25 AM
nasty_nos's Avatar
For what it is worth and I am not too familiar as to what may resolve this bit, Do Not Blame Your Mom! LOL.. You may want to check into your dual climate control. I am a new TL owner and not really familiar with everything. I would recommend searching the forum before anything. I personally would look into the electrical schematics if you can find them. There is a possibility that some sensor or something in the climate control has malfunctioned. Once again, I am a NOOB and just purchased my first TL a month ago!
Old Oct 17, 2010 | 02:22 PM
Sandals's Avatar
not to jump on your case but in your post you mention 3 times you are a noob. once will do just fine.
And i am not blaming my mom, it is just to show that I don't know what happened that day.
Old Oct 17, 2010 | 03:05 PM
I hate cars's Avatar
You might try sounding a little more grateful. I'm sure his intentions were not to annoy you.
Old Oct 17, 2010 | 10:37 PM
Sandals's Avatar
Sorry nasty_nos i was having a bad daily earlier. IHC your right i shouldn't be saying shit to anyone.
On a lighter note, for some reason heat was coming out of all 4 vents. Don't know why it wasn't working before.
this thread can be closed.
Old Oct 17, 2010 | 10:40 PM
That's weird. It almost had to be electrical since the water control valve had to be open for one side to get hot. Let us know if it does it again. My heat is starting to act up too.
Old Oct 22, 2010 | 08:40 PM
Sandals's Avatar
The problem came back just now, the passenger side is blowing cold air when it says it should be 81 degrees. The driver side is blowing hot air.
Old Oct 23, 2010 | 01:33 PM
pohljm's Avatar
maybe a vacuum leak on the doors that control the air flow to the vents? not sure if they are even vacuum controlled, but thats a common occurrence in many vehicles
Old May 9, 2011 | 11:34 AM
miltontls's Avatar
6th Gear
i have a 08 tl-s and i have no heat on the drivers side, also when i put it in cold i hear clicking like if something was trying to open but its stuck? try to put it in cold and see if u hear the clicking???????
SidhuSaaB
May 30, 2020 12:40 AM
LoneRonin
Jan 4, 2016 01:03 AM
detailersdomain
Wash & Wax
Oct 9, 2015 10:13 PM
Matthew Purpura
Sep 25, 2015 06:10 PM
95oRANGEcRUSH
Sep 25, 2015 12:50 PM
