heated seats
Originally Posted by ac08odl
for some reason my drivers seat gets really hot as if the heated seat was on. am i the only one? what should i do?
maybe first turn them off, or stop parking in the sun, or stop eating spicy food
Originally Posted by ecliptics
is it hot as if the heater seats were on? maybe theres an electrical problem that is making them turn on even though theyre off
what does this thing look like?
its silver(shiny-ish) in color and it looks like an "extra", meaning it looks like a separate piece between the car and the exhaust. there should be one right between the cat and the car.
but it could be an electrical problem. if you turn the heater on, does it get warmer or stay the same?
Originally Posted by SporkLover
Try pulling fuse 15 in your interior fuse box. That is the circuit for your seat heater. That will quickly eliminate/pinpoint whether it's a heat shield or electrical issue.
To know the differance:
try turning the seat heat on High for a few minutes- when its ON your butt will start roasting!
In normal operation you would use High for a few minutes to warm the seat, then switch to low and leave it there
See owner manual for details about overtemp shutoffs if left on high etc
well its random.....ill be driving and the seat gets hot.....seat warmers are off. heats off AC pumpin....all of a sudden my seats hot....im like wtf?! a few times ive gotten out of the car to see if its me or the seat......its the seat.
Push the right side of the switch, HI, to rapidly heat up the seat. After the seat reaches a comfortable temperature, select LO by pushing the left side of the switch. This will keep the seat warm.
In the HI setting, the heater turns off when the seat gets warm, and turns
back on after the seat’s temperature drops.
In the LO setting, the heater runs continuously. It does not cycle with temperature changes.
hmmm thats opposite of my 01
On high it will run till it hits the temp overlimit breaker and shuts off- then when it has cooled enough it will kick back on high
When on low it cycles on and off to maintain a medium temp
book says high to warm them and the run on low for sustained use
Even says not to run them both on high at idle as its a huge drain on the electrics
IS your ac set to 68- that should keep it cranking with just ac air
yea i did it....but i have to get the tsb done on the driver seat for the rod that "strips out".....well it snapped and took a gear with it, so the frame has to be changed.....ill ask to get the foam changed as well because it includes the heating element. i havent even gotten the drivers seat covered in suede because of it.
Originally Posted by Tripnbeats
it happens on mine too....weird. but only the drivers seat....thank god its getting replaced!
I went out to find towels on the seat--when my wife had been driving--smart girl~
Now she want sheepskin covers for the summer- hot leather and shorts -not a good combo
MrHeeltoe
20
02-23-2023 01:54 PM
MrHeeltoe
09-29-2015 10:43 PM
MrHeeltoe
09-28-2015 05:43 PM
