Headlight Restoration
Old Jun 8, 2010 | 01:51 PM
wrxyboy's Avatar
1st TL-S on air in
will the same concept of wet sanding it down with 1000 grit than sanding again with 2000 grit and finish with a headlight compound work on the inside of the clear lense. I was installing my zkwr and got some of the sealant on clear housing side, so i used goo gone to help remove it but it seams that the goo gone messed it up. So my first thoughts are that it should be ok to do so since the whole housing is made of one piece but i just need to be sure be for i go and mess it up even more.
Old Jun 8, 2010 | 02:27 PM
paz840's Avatar
Theoretically it should work, but I've never done it or seen anyone do it.
At this point, what do you have to lose?
Old Jun 8, 2010 | 02:29 PM
wrxyboy's Avatar
1st TL-S on air in
Thats my exact feeling right now. Worst case scenario is i have to buy a new headlight for the clear housing. But would i need to do the whole headlight or just the part that was messed up.
Old Jun 8, 2010 | 03:23 PM
Mug's Avatar
Mug
OUCH! What kind of sealant did you use? Did it actually mess up the plastic or can you just not get the glue off the lens?
I'd concentrate on the bad area. I'd use a high speed buffer with paint abrasives if it were me. NAPA has a nice line of different cuts depending on how aggressive you want to get with it. I'd take the light out too to prevent any paint damage.
Old Jun 8, 2010 | 03:50 PM
wrxyboy's Avatar
1st TL-S on air in
no this is inside the headlight so i would need to take it off the car bake it and separate the clear housing from the back housing. The damage is from goo gone, which i think as some kind of cleaner that eats away at plastic. So i am planning on using Meguiars PlastX to try and see if i can back to good shape but if that fails than i will try with the 1000 and 2000 grit sand paper.
Old Jun 8, 2010 | 04:00 PM
AMUA6's Avatar
ScoobyZINE
The PlastX does wonders on headlight lenses man. If all else fails, pick up a 3M headlight restoration kit. They are the sh!t, but mostly used for older corroded headlights.. I'm not sure how this will work with it being on the inside of the light. Whatever you do, make sure you use a buffer.
Old Jun 8, 2010 | 04:06 PM
rockstar143's Avatar
I really think it will work.
When I was a kid, I tried cleaning a sticker off a tape case with goof off and man did it get foggy.
Give it a whirl! If worst comes to worse, try the VHT on the amber portion (clear portion for you).
Old Jun 8, 2010 | 05:51 PM
wrxyboy's Avatar
1st TL-S on air in
would a wool pad be something i should be looking into or just a soft foam pad, or should i be using both.
Old Jun 8, 2010 | 06:18 PM
TheChamp531's Avatar
Chapter Leader (San Antonio)
Check my DIY in the 3G Garage on "restoring" the headlight. I'm lazy right now or I would link it for you.
Old Jun 8, 2010 | 06:19 PM
TLDude876's Avatar
Chapter Leader (Houston)
You can use P500 then P800 then P3000 sandpaper then use a plastic polish (preferably 3M) after. I did this over the weekend and was really pleased with the results given that my headlights had been sprayed with a smoked type of paint. Also I find it works better when you keep the sanding paper wet.
Old Jun 8, 2010 | 06:47 PM
wrxyboy's Avatar
1st TL-S on air in
Thanks for the help. But i think i will just try and buff it out first before i do any sanding. Ill leave the sanding for the last resort.
Thanks for the info
Old Jun 8, 2010 | 07:47 PM
poormans_tl69's Avatar
CARBON FIBER WDP TL
yes you can use both and it works great...i had an issue like this but a little less than yours...good luck
Old Jun 9, 2010 | 12:22 PM
zenki972's Avatar
I tried the resotoration thing on my driver headlight.
1.clean light
2.sand it useing some maybe 600 sp
3.wetsand it useing some 2k sp
4.buff and polish either by hand or if u have a mothers power ball like ido that works wondersa swell.
good luck
Old Jun 9, 2010 | 12:35 PM
wrxyboy's Avatar
1st TL-S on air in
1.clean light
good luck
I do have a mothers powerball but i was not impressed with it. But i do have a buffing kit and i will just need to buy the buffing heads. Thanks for the help though
hashbrown
Feb 18, 2022 11:20 AM
LogicWavelength
3G TL Photograph Gallery
33
Nov 1, 2015 09:38 AM
Mr.Tea
Oct 2, 2015 10:32 PM
h22lude
Sep 27, 2015 06:22 PM
AmplifiedDetails
Sep 24, 2015 02:55 PM
