Headlight Not Working Question :confused:
Old Aug 30, 2014 | 02:00 AM
shift_'s Avatar
8th Gear
Leaving work tonight I noticed that my driver side HID Low beam and High beam had stopped working! In addition, my driver side DRL is burnt out too.. The driver side turn signals work fine though (I have switchbacks if that accounts for anything). To add.. my driver side headlight does have a leak.. so there is a little bit of condensation inside the headlight since I had cracked them open to paint the housing, but I haven't had time to reseal them yet. Unfortunately, I'm not too familiar with anything electrical related.. so your help would be greatly appreciated!
Does anyone know what could be the issue? Please and thanks !
Old Aug 30, 2014 | 02:09 AM
AckTL05's Avatar
Former Sponsor
You probably burnt out your ballast since it sits at the bottom of the headlight. Thats why its very wise to seal up the headlight tight as possible. Fogging can come and go from temp change/etc…but leaks are very bad. I bet the fuse is blown as well…do not replace the fuse till you fix the issue or it will just keep blowing.
Also, make sure you get that fixed ASAP, because you maybe able to save the ballast.
Old Aug 30, 2014 | 02:11 AM
shift_'s Avatar
8th Gear
Thanks for the quick response! What would be the best way to check to see if it is the ballast?
Old Aug 30, 2014 | 02:13 AM
shift_'s Avatar
8th Gear
Also, I'm not sure if i used the term leaking correctly... But I noticed whenever I wash my car it starts to fog up a little bit after I leave the car wash.. Presumably because the water is so hot with the pressure washer so it fogs up when it cools down (ie temperature change)
TLrascal
Aug 3, 2018 11:00 PM
wusty23jd
Sep 24, 2015 11:41 AM
acurajj
Sep 19, 2015 03:47 PM
theinsvnity
Sep 10, 2015 10:22 PM
prox
5G TLX Problems & Fixes
Sep 1, 2015 02:03 AM
