Headlight leveling
Old Jan 22, 2008 | 09:22 AM
tlperson's Avatar
Headlight leveling
I have been searching but can not find the answer to my question. I was wondering if I could adjust my headlights so they are both the same height. I read somewhere that the driver’s side is lower than the passenger side so you don't blind people while you drive by.
Old Jan 22, 2008 | 09:38 AM
01tl4tl's Avatar
Thats correct- driver side aim is a bit lower and in to the center to protect oncoming drivers.
The passenger side is aimed a little to the right and farther up so you can see the edge of the road lines and pedestrians
There is an aduster on the back of the housing- use a + screwdriver to engage the cam gear.
If not certain how high or how to do, have a headlight inspection staion do it for you in a few minutes- check the phone book yellow pages
New shocks or worn shocks can really thro the lights off the correct position, and when they are right- wow can you see.
Also recommend Kaixen 6000k low beam bulbs- blue with white tint- very nice!
Old Jan 22, 2008 | 11:01 AM
Bearcat94's Avatar
AZ Community Team
There is a thread (in the 3G Garage maybe) that has Serivce Manual Scans of the Headlight adjustment. I believe it's measured at 25 feet out, but don't remember the height above the ground.
If the headlights are "stepped" so that on-coming drivers are not blinded, why do you want them the same height?
Old Jan 22, 2008 | 12:52 PM
tlperson's Avatar
I've looked for this + head adjusting cam gear but I can't find it. Does anyone know exactly where it is? Thanks for all the help guys!!!
Old Jan 22, 2008 | 12:57 PM
TeknoKing's Avatar
Can you PLEASE take a photo of your beams against the wall and on a dark flat surface. I'm still having issues with my bulbs, and they are driving me nuts. Thanks
Old Jan 22, 2008 | 01:02 PM
TeknoKing's Avatar
Umm, open the hood, on left and right black plastic covers, you will see a hole with words UP/DOWN written on them...now use a #2 philips screwdriver, and at an angle put it and turn. Use a flash flight to find the hole
(if you still can't find them, follow your headlight position, and follow that upwards [towards the end of the engine bay]....the holes will be about 10 inches from the headlights straight.)
Old Jan 22, 2008 | 01:27 PM
Bearcat94's Avatar
AZ Community Team
Originally Posted by rets
Here's the SM scan - you may have found it already.
And seriously, as a fellow driver and potential victim, don't F around with the headlight aiming - these lights are BRIGHT. Those goofy a$$holes who d!ck theirs up so the car looks Cock-Eyed or Cross-Eyed should have their licenses revoked.
hashbrown
Feb 18, 2022 11:20 AM
Mr.Tea
Oct 2, 2015 10:32 PM
MilanoRedDashR
Sep 27, 2015 10:15 PM
h22lude
Sep 27, 2015 06:22 PM
AmplifiedDetails
Sep 24, 2015 02:55 PM
