Tire pressure issues.....
Old Jan 21, 2008 | 01:51 PM
Acura Diver's Avatar
My TL runs great but I have noticed a very annoying little problem with the tire pressure. Whenever the temperature outside drops to below 20 degrees or so, the tire pressure in my driver side rear tire loses about 7-8 lbs. I refill it, and it is fine for a while until the temperature drops again!
I've checked for small puntctures, etc, etc but the tire looks very good.
Does anyone else have this issue? Thanks for the input and I apologize if this is a subject already beat to death!
Old Jan 21, 2008 | 02:04 PM
korrupted's Avatar
J35A8
Are you relying onthe TPMS or are you doing this manually?
Old Jan 21, 2008 | 02:05 PM
TeknoKing's Avatar
hmm, usually 1psi per 10 degree of temperature change. But then again -20F is pretty damn cold.
Have you checked the actual valve core (stem)? Maybe thats leaking air, just simply put a drop of saliva on top, if a bubble forms without breaking up, than it's good, no leak.
I had that problem on my other cars, but once I replaced the stem, a few bux, the problem went away.
Old Jan 21, 2008 | 02:06 PM
Jesstzn's Avatar
Has the tire shop submerged the tire in water ot you checking visually?
Also it could be the valve in the stem. After you air it up spit on your finger and run it over the top of the stem to make a membrane and see if leaking air makes a bubble.
Old Jan 21, 2008 | 02:21 PM
Thanks for the responses. I am relying on the TPMS.
I thought it might be a small leak, but I took the car cross country for a few weeks and never had the issue! Once I came back to the New York area and the temperature started to really flucuate, then the problem started happening again. Very odd because it only happens to one of the tires!
Guess I will have to take it in and have it looked at!
Old Jan 21, 2008 | 02:31 PM
TeknoKing's Avatar
Ok, never rely on the TPMS for precise results. Use a tire pressure gauge to monitor your tires. Your TMPS sensors maybe wrong.
Old Jan 21, 2008 | 02:38 PM
korrupted's Avatar
J35A8
It is strange that you are losing air only in one tire.
You should try checking it manually.
Maybe the TPMS module is not working correctly.
Old Jan 21, 2008 | 02:40 PM
lights's Avatar
Engineer
The TMPS SHOULD be right....or else why would Acura put something that don't work on their vehicles???
Old Jan 21, 2008 | 02:45 PM
TeknoKing's Avatar
This is my 3rd car with TMPS, they are NOT accurate, it is an approximation. I'm very anal about my PSIs, I only use TMPS to make sure I'm not losing air, but not how much air I actually have.
TMPS definitely works, however, it is a not a precise instrument that a gearhead would use. my of course.
Old Jan 21, 2008 | 04:51 PM
It is very odd that it is only one tire. So either the TPMS is not functioning corectly or the tire is losing air.
Since I have been pumping 7-10 ibs in the tire for the last 3 weeks or so, I suspect the tire is losing air and the TPMS is working correctly.
But the tire does not lose air on a regular basis llike it normally would if it were a leak. Only when the temp changes and only in that one tire.
I hate having to pull over into a gas station at night after work and refill one tire. It's a real pain.
Old Jan 21, 2008 | 08:09 PM
jumbosizeme79's Avatar
aTLien
dont fully trust your TPMS simple reason
when weathers cold air condenses and gets packed tighter it fools the TPMS, thus
thinking your tires flat, when you have warm weather air expands making the the air
in the tire expand and making it seem like there more air. it should be fine all the
other wheels are ok, but you might wanna manually check it just inase
Old Jan 21, 2008 | 08:46 PM
CAPS's Avatar
Talking
fill with Nitrogen and you won't have that much fluctuation. was -20c outside the other day and my tps was going crazy, giving me low pressure warnings on all tires. as i started driving after 15min the warnings went away as the temp/pressure went up.
my bro runs Nitrogen in his RX8, and it's the only way he rolls.
I had air in my tires, summer settings, 240 in the front and 220 in rear after warm up. in -20 front went down to 184 and 164 in the rear on a cold start. now ur tps warnings come on real nice.
Old Jan 21, 2008 | 08:59 PM
mmade22's Avatar
200,000 mile club
Sorry to be off topic ......Hey Acura Driver, after last nights game, I think it's time to change the aviator.
Old Jan 22, 2008 | 02:43 AM
darksky's Avatar
I don't buy that whole nitrogen in tires resists pressure fluctuation more than "air" in tires. All gases follow the Ideal Gas Law and will expand/contract with temp changes. Approx. 78 % of the air you're breathing right now is nitrogen and about 20 % oxygen. The other 2 % is argon, CO2, methane, H2O vapor, and other gases. My point is that compressed air is about 78 % nitrogen right now.
If I remember my highschool chemistry, nitrogen is only 1 proton less than oxygen (15 vs. 16). This means that pure nitrogen in the PV=nRT equation will resist a temp change or pressure change by about 1/16th more than pure oxygen (or is it doubled since oxygen is O2 not O)? My point is you're already @ 78 % nitrogen, if you go to 99 % the change will not be that dramatic at all. The only advantage I see to using pure nitrogen is that there shouldn't be any water vapor in the tire that might have some effect at keeping it from dry rotting from the inside assuming the air used was REALLY wet and that dry rotting from the inside-out is a problem.
That's my
Old Jan 22, 2008 | 11:16 AM
Bearcat94's Avatar
AZ Community Team
Don't crap on a good marketing campaign with a little science. It's un-American.
(It is O2, but the gas you use to fill with Nitrogen is N2.)
Old Jan 22, 2008 | 11:24 AM
mmade22,
Change my Avatar? NEVER! They had a good season but it ended on a very bad note. Next year will be great!
Thanks for all the tips guys!
Old Jan 22, 2008 | 03:11 PM
darksky's Avatar
You're right... both are diatomic. So O2 or N2 you're talking about a difference of 32 vs. 30 in the n term of the equation or ~7 %. Also remember we're not comparing pure O2 to pure N2; we're comparing about 80/20 N2/O2 vs. 100 N2. So in round numbers, about 2 % difference from the 80/20 mix to pure nitrogen. 2 % isn't shit! That whole "pure nitrogen" in tires is a scam... and if you believe it, then I have some magic beans I'll sell you
Old Jan 22, 2008 | 03:45 PM
TeknoKing's Avatar
darksky, I want some magic beans, lol
Such businesses don't expect the public to have the basic chemistry knowledge or read between the lines.
Did any of you've seen the Discovery 2057 shows, where they showed those sick looking tires, which had no tubes, but threaded design?
udelslayer
1G RDX Problems & Fixes
May 6, 2016 12:27 PM
mugen_kid
Nov 13, 2015 10:38 PM
NBP_BALLER
Sep 23, 2015 08:18 PM
CostcoFanAUS
Sep 18, 2015 06:05 AM
HeloDown
Sep 8, 2015 06:51 PM
