Headlight flickering
Old Mar 19, 2020 | 03:40 PM
Alec Sklutovsky's Avatar
6th Gear
My front left headlight is flickering and going out. Unlike the other person who had this issue, my igniter is fine. I swapped both ballast and igniter in from the right side and I am still having the same issue. My guess is that its either the wiring harness or fuse. The fuse looks fine so my bet is on the wiring harness. Any help is welcome : )
Old Mar 19, 2020 | 03:52 PM
Did you move the bulb by chance?
Old Mar 19, 2020 | 06:04 PM
6th Gear
The bulb is new and positioned correctly
Old Mar 20, 2020 | 12:41 AM
vpasla1's Avatar
What bulbs did you buy? From where?
it wouldn't hurt to swap them to see if the problem carries. Was it happening before replacing the bulbs?
Old Mar 20, 2020 | 07:57 AM
6th Gear
I plugged the right headlight assembly into the left wire harness and the same thing happened.
Old Mar 20, 2020 | 11:04 AM
check the grounds on the left side of the car.
Old Mar 20, 2020 | 03:31 PM
6th Gear
The grounds are all connected on one piece, as long as it is touching the body I am ok, right?
Old Mar 20, 2020 | 04:10 PM
i'd remove it and grind/sand down the mating area to make sure it's making a clean contact. Check the wires themselves to see if they are corroded; it happens internally sometimes
nmcallister
Sep 15, 2014 12:15 PM
Eastboy123
2G CL Problems & Fixes
May 4, 2013 04:52 AM
scorleo
Oct 13, 2008 08:07 AM
006r
Jun 21, 2006 01:35 PM
