Headlight issues
Old Sep 13, 2014 | 02:12 PM
nmcallister's Avatar
4th Gear
Headlight issues
I have an 03 tl. My passenger side headlight was out, replaced the bulb, ballast, still out. Anyone have any ideas as to what it could be?
Old Sep 13, 2014 | 02:43 PM
YeuEmMaiMai's Avatar
check ur fuse
Old Sep 13, 2014 | 04:08 PM
MarbleGT's Avatar
'08 MX5 GT 6spd.
Could be a ballast as well.
Old Sep 14, 2014 | 10:24 AM
4th Gear
Checked all fuses, but took the "new" ballast out to send back to seller. Going to try a different one. Just wasn't sure if these cars were prone to wiring issues or what. Thanks for the help.
Old Sep 15, 2014 | 12:15 PM
01tl4tl's Avatar
highly prone to water based failure of the ballast and the igniter
Most on here go aftermarket when the problem of one light works sometimes- have to flick switch to make it come on again etc
HID Kits | Conversion Kits | Xenon Headlights | HIDeXtra is one supplier we like and supports this site for us, ck vendor list
get a `kit` that has 2 new modern ballast and ignitors- with needed connector wire to bulbs and 2 nice bulbs
suggest you stay at 35 watt ballast (stock size) and 5000k bulb color for close to stock
you can pay from $ 70 -200 depending on maker, but its all better than 15 year old parts and technology of the original system
no extra relay needed since we have hid already- just replacing the worn parts in total- hid systems are picky about volts amps and resistance- best to buy a package thats made to work together
tman570
Jun 11, 2019 07:56 AM
TLrascal
Aug 3, 2018 11:00 PM
acuraST
Sep 17, 2015 02:31 AM
JnC
Sep 11, 2015 06:06 AM
prox
5G TLX Problems & Fixes
Sep 1, 2015 02:03 AM
