Headlight aim
Old Feb 18, 2022 | 01:44 PM
BigTiz's Avatar
BigTiz
Headlight issues
Replaced bulb on drivers side but headlight still not working? Could anyone help me with this problem. Could it be ballast?
Old Feb 18, 2022 | 02:54 PM
peter6's Avatar
Could be. Check fuses, swap ballasts / igniters side to side.
Old Oct 24, 2023 | 09:05 PM
BigTiz's Avatar
BigTiz
headlight issues
Been having trouble with my driver's side headlight. Installed new lights all the way around. Fog, headlights and high beam .suddenly the driver's side isn't working at all. These are aftermarket from Amazon if it matters
Old Oct 24, 2023 | 10:53 PM
Superunknown's Avatar
Amazon D2S bulbs are garbage, so yeah, it matters.
Old Nov 10, 2023 | 06:44 PM
BigTiz's Avatar
BigTiz
Headlight aim
My drivers side headlight is aimed too low. Can Someone instruct me on how to aim it properly I have looked for The adjustment screw from videos I've seen but my 2000 8TL does not have that screw As I've seen on the video
Old Nov 16, 2023 | 12:32 PM
MyGuti's Avatar
The screw is there. Look closely.
It is kindve hidden upwards
Old Nov 17, 2023 | 02:09 AM
mariusz439's Avatar
.... and it can be hard to move if it wasn't moved for some time....
Old Dec 21, 2023 | 08:57 PM
BigTiz's Avatar
BigTiz
headlight issues
I am still having trouble with my driver side headlight. I have replace the bulb and ballast once before. Just replaced the bulb 2 weeks ago. It blew and is no longer working after 5 days. Bought another igniter with ballast and bulb. This will be my 3rd build replacement and 2nd ballast replacement. Help and advice is much needed
Old Dec 21, 2023 | 11:23 PM
Jackass's Avatar
Symptoms? What have you done? Have you swapped parts across the car? What replacements are you using? Can't help if you don't give us anything to go off of. Pretty much the same stuff mentioned on your previous thread.
RalphiieP
Jun 8, 2008 09:56 PM
BlueXTC
May 23, 2002 11:43 PM
