Harmonic balancer in '07 TL
Old Jul 13, 2014 | 10:46 PM
purekhan's Avatar
my harmonic balancer in 07 tl went bad ...I want to replace it but should I go with stock or the light weight performance crank pulley ...need some feedback ..thank u
Old Jul 13, 2014 | 11:23 PM
vietxquangstah's Avatar
Your harmonic balancer went bad? How? What happened for you to find out?
After market performance lightweight crank pulleys DO NOT HAVE A HARMONIC BALANCER.
If you want a harmonic balancer your only option is to go with a OEM pulley.
Old Jul 14, 2014 | 12:21 AM
pbook4g5's Avatar
These engines are internally balanced. The OEM crank pulley isn't explicitly a harmonic balancer. However, its weight allows it to absorb some of the resonant vibrations that may be present.
I had a UR lightweight pulley on my car for years with zero issues. Over 150k miles with it. You'll be fine if you replace the OEM with a lightweight one.
Old Jul 16, 2014 | 03:53 PM
purekhan's Avatar
couple days ago ...I took off the fender cover ...then run the engine it made a ticking noise ..then I see the balancer wobble and when I turned on the A/C it went worst ....I stick a pen on it and bouncing bad
Old Jul 16, 2014 | 05:02 PM
pbook4g5's Avatar
If you had a weight at the end of the crankshaft that was out of balance, of course it would make noise. Was it lose? I don't know how an 11lb solid pulley just goes bad...
Old Jul 16, 2014 | 05:13 PM
^agreed.
unless it was hit or banged on. but highly unlikely.
could the OP take a picture or a video of the subject in question?
Old Jul 16, 2014 | 05:19 PM
pbook4g5's Avatar
What I meant to say by was it lose was.... was it loose?
And I'm a teacher. I fail.
Old Jul 16, 2014 | 05:22 PM
Old Aug 10, 2014 | 12:43 PM
Legendliving's Avatar
I can tell you what happens when it goes bad , it ruined last weekend, it starts off rattling then if you ignore it, the thing breaks into its two component parts and the belt comes off. I have all the tech on mine so comes with electric steering so I was able to drive on until the battery was flat. Had it trailered home and now waiting for the part to be flown in from Japan. 105,000 miles on the clock.
Old Aug 12, 2014 | 12:58 AM
Bearcat94's Avatar
AZ Community Team
The general consensus is that it's not a 'balancer'. But it does have a rubber-like insert, so it is/may be a noise and/or vibration dampner.
Originally Posted by pbook4g5
.....I don't know how an 11lb solid pulley just goes bad...
I think it's two pieces .... there's a rubber insert between the hub and the outer part of the pulley.
Old Aug 12, 2014 | 11:01 AM
1black_seven's Avatar
Slot Machine Lubricator
You can have mine for no cost, just pay the shipping. It has 90k miles on it. I replaced it with the UR pulley a few years ago.
Old Aug 12, 2014 | 12:54 PM
pbook4g5's Avatar
Guess its different than the pulley on the 7th gen Accord V6 then... that was just a solid metal pulley.
Old Aug 12, 2014 | 10:09 PM
Bearcat94's Avatar
AZ Community Team
Sounds like it. There is definitely a rubber insert ..... that's the NVH dampner.
Old Aug 12, 2014 | 11:41 PM
pbook4g5's Avatar
Same part number as the Accord.... weird. I don't know. Mine had no rubber insert.
Feb 25, 2020 09:57 AM
udelslayer
1G RDX Problems & Fixes
May 6, 2016 12:27 PM
jsonkimz
Mar 28, 2016 07:49 PM
joflewbyu2
Oct 8, 2015 11:16 AM
Brandle34
Sep 23, 2015 07:20 PM
