Grinding on slow movement and braking
Old Sep 23, 2010 | 06:08 PM
bcan1ne's Avatar
Am i right to assume that this grinding on slow movement and braking is just my brake pads or are my rotors probably bad as well? Thanks in advance
Old Sep 23, 2010 | 07:33 PM
Turbonut's Avatar
If the pads are shot and metal is contacting the rotors, kiss the rotors goodbye. Need to pull the wheel and take a look unless you can see the rotor face being damaged by the pads.
Old Sep 23, 2010 | 07:48 PM
VQPower37's Avatar
x2 ... need a brake job asap
Old Sep 24, 2010 | 06:46 AM
SouthernBoy's Avatar
Registered Member
Grinding sounds coming from the wheel area are never good sounds. Check those rotors right away. And check the pads, both inside and outside, for life.
Jul 16, 2017 07:33 AM
xsilverhawkx
Oct 5, 2015 11:00 AM
27trains
4G TL Problems & Fixes
Sep 30, 2015 09:44 AM
hashbrown
Sep 29, 2015 12:13 PM
