Grinding Noise when Turning
Old Jan 17, 2011 | 10:00 PM
Toddy's Avatar
Registered Member
If I make a sharp left I can hear a grinding noise coming from my passenger front. Im not sure what it is. I haven't had time to pull the wheel off to look but I'm thinking its a bad axle shaft. Any thoughts
Old Apr 27, 2012 | 02:01 PM
VT-TSX's Avatar
I'm having the same issue when I make sharp, low speed turns. Like in parking lots or out of driveways. Seems to happen more often turning left than right. What was the issue with yours??
Old Apr 27, 2012 | 02:13 PM
Aman's Avatar
Your Friendly Canadian
I got the same thing, going to check it out in a few hours. Thinking either a bad axle or something with the brakes.
Toddy's Avatar
Registered Member
Bad passenger half shaft
Old Apr 27, 2012 | 02:14 PM
VT-TSX's Avatar
How much did that repair run you, if you don't mind me asking?
Old Apr 27, 2012 | 02:16 PM
VT-TSX's Avatar
Mine doesn't happen all the time, its very sporadic. I was thinking about taking into the dealership but I can't duplicate the problem so I didn't' want to waste everybody's time with a "phantom" problem.
Old Apr 27, 2012 | 03:22 PM
AnthraciteAspec's Avatar
RPF1+RS3 FTW
Hmm, my car makes noises when I make sharp lefts. Comes from the passenger side as well. Mine sounds more clunky than grinding though. Might need to look into this more...
Old Apr 27, 2012 | 05:58 PM
Ccvn0's Avatar
It seem like a bad axel
Old Apr 27, 2012 | 07:01 PM
Toddy's Avatar
Registered Member
160 for the axle from delay acura and my tech charges me 60 to put it in
Old Apr 27, 2012 | 07:17 PM
flyromeo3's Avatar
i thought bad axles click. as in bad cv joint.
Old Nov 14, 2018 | 11:05 PM
Aspectl-S's Avatar
integrahed
Same problem. Just put in new axles on both sides. Still hear it?? Now I'm really confused
Old Mar 24, 2024 | 07:36 PM
Geezey617's Avatar
did you ever figure out what the grinding noise was my Acura RL is doing it too when I turn left
Old Mar 25, 2024 | 09:55 PM
Canadiandemon's Avatar
I had a similar problem, was able to replicate it when the car was off. When car was jacked up, it stopped grinding. It ended up being a bad tie rod end.
Feb 25, 2020 09:57 AM
jblessing
Aug 8, 2018 09:43 PM
Frathora
Sep 28, 2015 11:29 PM
PortlandRL
Sep 14, 2015 12:01 PM
aces2412
3G MDX (2014-2020)
Sep 7, 2015 08:40 PM
