Grinding noise when rolling down front driver side window
Old Jun 19, 2008 | 10:58 AM
Roth203's Avatar
Honda4LiFe
I noticed a slight strange grinding sound when rolling down my window..it happens most when the window is just rolled half way down..so i bring it to acura and they say its the window regulator and would cost $248 installed but is not covered under warranty because I have tinted the windows..wondering if anyone else has experienced this problem
Old Jun 19, 2008 | 11:05 AM
TeknoKing's Avatar
that's pure BS!
The dealership just wants to make cash on you.
Which dealership?
Old Jun 19, 2008 | 11:11 AM
Thorin78's Avatar
Previous Owner
Ya I have the same issue now and then. I think it has to do w/ the grease, after I roll it up and then roll it down again, there's no noise.
Old Jun 19, 2008 | 11:18 AM
racerxx's Avatar
when my accord started making this noise, it was a matter of days before the cable started to self destruct and shreaded....that is when i traded in the car and got the type s....i believe they quoted me more like 500 bucks...which is what i think the tl would cost since its the same part....or similar atleast....as far as the warranty that is bs....
i would like to see them try that with me....i paid the dealer for window tint which they say is warranty for life of the car....
Old Jun 19, 2008 | 11:40 AM
Frankie02's Avatar
DoublYouDP
YES I got the same problem so i bought the car down to the dealer and wat they did is take the door apart and lube the rail and clean out the dirt and stuff that sittin' on the rail....that's why everytime when you roll down or up you'll hear that grindin' noise...
Old Jun 19, 2008 | 11:53 AM
Roth203's Avatar
Honda4LiFe
Originally Posted by TeknoKing
that's pure BS!
Which dealership?
Devan Acura Located in Norwalk, CT
Old Jun 19, 2008 | 12:01 PM
08 wdp type s's Avatar
i hear it too...so you guys r saying if there tint on the windows the its not under warranty no more?
Old Jun 19, 2008 | 12:22 PM
Tripnbeats's Avatar
no thats pure BS they wanna cash in on people... at which point you can tell they are a bunch of jerk offs.....i would go to another dealer and when they call from the one i left i would give them 0 across the board for satisfaction. and id call HQ and report them because they offer to tint the windows as an added feature/option/whatever u wanna call it when u buy the car which would cause it to "break" regardless.....so they cant use that as an excuse......theres ONLY 1 way to tint windows....not 30 and acura doesnt have the "correct" proedure on it.....they have the same one everyone else uses.
Old Jun 19, 2008 | 12:44 PM
SRT-11's Avatar
Quiet, Rika Neenja!
my rear drivers side window makes a noise when it's rolling down that sounds like a bearing failure, but maybe it's a dirty track? I'll try greasing it and see if that helps 'er out.
Old Jun 19, 2008 | 01:32 PM
1995hoo's Avatar
Keep Right Except to Pass
The driver's window in my 1988 RX-7 started making a grinding noise in May and a week later it would only go down halfway. (Thankfully, I could put it back up.) It came to a lot more than $248 installed, though, perhaps partly because I needed a new window motor that they wound up having shipped from somewhere in Canada (finding parts for that car is no longer so easy). I'd suggest that you try another mechanic for a second opinion but that you not put off having it fixed. I was lucky that my window went back up.
The part about the tint voiding the warranty seems suspicious to me, but then I don't have tint on either car so I'm no expert.
Old Jun 19, 2008 | 02:07 PM
Roth203's Avatar
Honda4LiFe
Thats what this guy in service told me??
Old Jun 19, 2008 | 02:08 PM
Roth203's Avatar
Honda4LiFe
funny thing is i didn't buy my car from this dealership i stopped going to my original dealer because the service is horrible..i just wanna fix it while the car is still under warranty
Old Jun 19, 2008 | 03:21 PM
stillhere153's Avatar
94 DC4 RS LSV/Turbo
mmmh.... you guys are hearing something that is typical when dirt gets in there... I just go to autozone and get silicon spray... works everytime...
this happend to my car when it was 3 months old... I put tiny bit silicon spray on it... hasn't come back since
Old Jun 19, 2008 | 11:38 PM
rayl's Avatar
Yes, I have the same problem on both of my front windows, sometime the noise gone for few weeks then come back to bother you for another few weeks...... Technician in my dealer's place tried to clean the rack, it works only few days then problem come back again.
Old Jun 20, 2008 | 07:27 AM
SRT-11's Avatar
Quiet, Rika Neenja!
is there a DIY or a how-to on where to spray the silicone? I have a can of it and I'd love to bang that out real quick...
Old May 16, 2013 | 02:02 PM
fuffty's Avatar
3rd Gear
I'd love to find the answer to this as well, as the same thing is happening to our '08 right now. I thought it was the window regulator going, but if there's a quick fix that I can do, even better!
Old Aug 6, 2013 | 12:34 AM
Gil'sUA5's Avatar
Have this noise on my driver side window, its intermittent and its extremely loud and annoying, should i try cleaning and lubing up the track?
Old Aug 8, 2013 | 02:17 AM
dcmodels's Avatar
TSB 10-014 describes cleaning and lube procedure for window tracks, using Shin-Etsu. I think you could also use SuperLube from ACE hardware. Shin-Etsu is basically thinner di-electric silicone grease, which I think might be too thick. I have cleaned with ArmorAll Original protectant, then lubed w/ SuperLube.
Most (or all) TSBs are listed somewhere on this site.
Old Aug 8, 2013 | 11:01 AM
Gil'sUA5's Avatar
Would i be able to use white lithium grease? I used it for my passenger side mirror and it worked great.
Old Aug 10, 2013 | 01:16 AM
dcmodels's Avatar
1) Lithium gease is for metal - it will degrade/ damage plastics and rubber - esp. plastic gears under pressure. Its basically chassis grease, great for metal such as door hinges, hood latches, etc. if you can get it to flow into those tight areas. Would work on window gear mechanisms, levers, etc. if metal. The thinner versions (NLGI 1) would be marginal inside the door, because it would wash away. The NLGI 2 chassis grease version would be better there.
2) Shin-Etsu (expensive) and Dielectric (cheap) silicone grease is for rubber, plastic, etc. - Honda specified for door and window seals. Do *not* use spray aerosol versions of silicone grease. The grease is OK, but the aerosol solvents will damage rubber.
3) SuperLube is a synthetic PAO based grease containing teflon - GM specified for rubber, plastic, and metal combinations such as door/ window rubber seals, door hinges, hood latches, door key locks, etc. Available in spray (aerosol) and tube - cheap.
4) Dow Corning MolyKote MH-62 Honda p/n 08798-9012 is for plastic and metal combinations - Honda specified for HVAC plastic door pivots, plastic linkages, etc. - expensive.
https://acurazine.com/forums/showthread.php?p=13884378#post13884378
I stated what Honda recommends in the TSB - read it. But use what you want, where you want.
Old May 9, 2014 | 03:11 PM
quanTL's Avatar
Fixed the grinding noise when the Window is half open and trying to close or open. I took apart the door panel. There are two bolts that is holding the window in place on the track. Both bolts were loose and was not holding the glass snug. I righted the bolts and silicone sprayed the tracks. Now smooth as silk and no more annoying grinding noise and clicking noise. Check this before you go jumping to replacing the regulator.
csmeance
Jan 7, 2026 06:25 PM
Feb 25, 2020 09:57 AM
nanos
Nov 12, 2015 08:41 PM
Ny1718
Sep 11, 2015 09:21 AM
08 NBP TL
Sep 8, 2015 08:49 PM
