Glove box key problem
Old Feb 4, 2012 | 04:39 PM
acidikelmnt's Avatar
7th Gear
I tried locking my glove box compartment but the lock wouldn't turn when i put in my master key.
I don't know if i'm missing a step to the locking process or what but I'd imagine it be simple by just inserting the master key and turning it to lock. Maybe it's a lock defect.. I don't know.
Anyone know how I can fix this problem?
Thanks!!
Old Feb 4, 2012 | 05:27 PM
Will1688's Avatar
Do you have the pass through in your trunk from the center seat? try the master key there, if it doesn't work then you had a similiar problem like me, i took it to the dealer and they did something to fix it.. although til this day im not exacly sure what they did lol
Old Feb 4, 2012 | 06:01 PM
Will Y.'s Avatar
Registered but harmless
Is the head of your "master key" black or gray?
If gray, that's the valet key, which is not machined to open the glove compartment or the trunk pass-through.
If the key you are using is one of the black ones, then the glove box lock is misaligned, or the lock pins or key teeth are excessively worn.
Old Apr 3, 2012 | 09:03 PM
BeeTam89's Avatar
Hey OP, did you remedy the problem? I'm having the same issue, haven't tried the pass through in the trunk though...going to see if it works there. I tried both master key 1 & 2, neither works for the glove compartment.
Old Apr 4, 2012 | 05:12 AM
BeeTam89's Avatar
Checked the keys on the trunk pass through, didn't work there either. Will I definitely need to go to the dealer to fix this?
Old Apr 4, 2012 | 10:00 AM
Will Y.'s Avatar
It sounds like your master keys are not the originals-- either they are copies made from the original valet key or your ignition was rekeyed for some reason.
If you bought the car CPO, the dealer should fix the issue.
Otherwise, you'll have to pay for new keys OR new glove compartment and pass-through locks.
spidermankb
Mar 5, 2019 11:34 AM
oyayjoe
Jan 1, 2019 10:17 PM
whitesoxsfan12
Sep 13, 2015 02:09 PM
oyayjoe
Sep 12, 2015 04:40 PM
whitesoxsfan12
Sep 7, 2015 04:07 PM
