Getting some rough noise when in reverse
Old Jan 3, 2013 | 09:32 AM
cipdagr3at's Avatar
HASTA LA VICTORIA'
Unhappy Getting some rough noise when in reverse
I changed out the front and rear motor mounts. Just last week Im getting the same noise I did when the mounts went bad..Any idea what could be the problem this time.. I get alot of noise when in reverse on a hill like its forcing the engine alot..
Old Jan 3, 2013 | 09:59 AM
MEKO's Avatar
Changed with OEM part?
How about the side one?
https://acurazine.com/forums/3g-tl-problems-fixes-114/heavy-vibration-even-after-changing-all-three-motor-mounts-877147/
Old Jan 3, 2013 | 10:29 AM
cipdagr3at's Avatar
HASTA LA VICTORIA'
https://acurazine.com/forums/showthread.php?t=877147
Yes, changed with new OEM mounts... The side does look a little worn out but not as bad as the front and rear over the summer.. Can that be it??
Old Jan 3, 2013 | 10:52 AM
MEKO's Avatar
Really?
My rear was perfect, no problem.
Side was the worst one
Front was loose, broken
I say check the side one again
Lastly tranny mount
Old Jan 3, 2013 | 11:20 AM
cipdagr3at's Avatar
HASTA LA VICTORIA'
Really?
Lastly tranny mount
I thought after front and rear are replaced the side is just a support... guess not.. Ill give it a look after work today.. Thanks
Old Jan 3, 2013 | 11:29 AM
MEKO's Avatar
Yup, that's what I thougt too. That's why I said just check it, but side was the worst one on mine.
Front was ok, rear was perfect
and you saw how the engine was jumping on my video
Good luck, keep us updated
Old Jan 3, 2013 | 12:46 PM
cipdagr3at's Avatar
HASTA LA VICTORIA'
Will do, Thanks Meko!
Old Jan 4, 2013 | 09:15 AM
mb1976's Avatar
As far as mounts are concerned I thought the front ones go out first, and then side then rear, then the rest of tranny mounts?
Old Jan 4, 2013 | 10:38 AM
MEKO's Avatar
Most likely yeah
But I don't understand why he still has that noise on reverse.
I had the samething, went away after new mounts.
That made me think, it's not the tranny mount
MrHeeltoe
20
Feb 23, 2023 01:54 PM
SexyRL
4G TL Problems & Fixes
Aug 19, 2016 10:03 PM
xsilverhawkx
Oct 5, 2015 11:00 AM
MrHeeltoe
Sep 29, 2015 10:43 PM
MrHeeltoe
Sep 28, 2015 05:43 PM
