Gauges and wiper switch not working
Old Oct 7, 2010 | 12:20 AM
steadyspeedin's Avatar
I installed my iSimple yesterday. Once I put everything back together, i tried to turn my wipers on and nothing happened. No matter where I move the switch, nothing will happen. My second problem is my gauge lights. Whenever I unlock the car and get in it, the red+blue dashes/pins will light up. The LCD screen will also say driver 1. None of the MPH numbers are lit up. Then, when I turn the headlights on, the whole gauge cluster goes black. I see NOTHING. I can open the door and get them to come on again, like it does when I unlock my car (mentioned above). Does anyone know why this is? It's driving me nuts. Any help is greatly appreciated.
Old Oct 7, 2010 | 01:15 AM
nfnsquared's Avatar
I'd go back and check everything you did when you did the install.
Wiper is fuse #11
Gauge control module fuses are #7 and #21.
Old Oct 7, 2010 | 10:50 AM
Any other possible solutions besides the fuse? Every wire is connected
Old Oct 7, 2010 | 11:32 AM
nfnsquared's Avatar
Yeah, something you did during the iSimple installation most likely caused this and all the other problems you are suddenly having:
https://acurazine.com/forums/3g-tl-audio-bluetooth-electronics-navigation-94/help-problem-radio-794018/
Are all the dip switches off?
Totally disconnect the iSimple and re-connect the original wiring. Do the problems go away?
Old Oct 7, 2010 | 11:50 AM
https://acurazine.com/forums/showthread.php?t=794018
The dipswitches aren't off because the manual said not to touch them unless instructed to. My radio lights are fine now. The ipod also works fine. Its only the wiper switch and the gauges now. The gauges work, they just don't stay on. I can record a video and show you exactly what I'm talking about
Old Oct 7, 2010 | 12:12 PM
nfnsquared's Avatar
Originally Posted by steadyspeedin
The dipswitches aren't off because the manual said not to touch them unless instructed to....
Huh?
From the Honda/Acura installation instructions:
Step 4: "All 4 dipswitches must be set in the OFF (up) position for proper operation."
http://peripheralelectronics.com/per...HD1_manual.pdf
From the iSimple self install tips:
KEEP:
All Dip‐Switches Turned “OFF” Unless Instructed Otherwise
As of 9/01/08 there are only 3 types of vehicles that require dipswitch settings:
• Ford/Lincoln/Mercury (see iSimple GateWay owners manual)
• Volkswagen (see iSimple GateWay owners manual)
• Nissan (see iSimple GateWay owners manual)
http://isimplesolutions.com/ipod-ada...all%20Tips.pdf
Old Oct 7, 2010 | 02:15 PM
I overlooked a fuse man. All that headache for nothing haha. I appreciate your help. I don't know what I would do without this forum. Thanks so much for your help!
Old Oct 7, 2010 | 03:52 PM
nfnsquared's Avatar
Which fuse?
Old Oct 7, 2010 | 03:58 PM
#21. I picked the wrong row and checked the wrong one
Old Oct 7, 2010 | 04:10 PM
nfnsquared's Avatar
Good deal, glad it's fixed. Sometimes you just gotta take a deep breath (or sip a brewski) and then retrace your steps...It's the simple things that get ya!
csmeance
Jan 7, 2026 06:25 PM
mada51589
Jan 9, 2025 04:40 PM
acurajj
Sep 19, 2015 03:47 PM
ahsm
Sep 9, 2015 08:35 AM
