Front Suspension clunk on my 2007 TL - Type S
Old May 8, 2007 | 09:11 AM
virafp's Avatar
When driving over a speed bump, the front suspension has a pronounced "clunking" sound. It appears to be more noticeable when the strut is being extended. Again, sounds like a faulty bushing or something in the front strut assembly.
It is also noticeable on rough roads, along with the rear suspension noise.
My car has 500 miles on it, and this is very disappointing.
Anybody else have the front suspension issue as well?
Viraf
Old May 8, 2007 | 09:47 AM
Silver_Surfer's Avatar
Happy Holidays!
Not too much from the front...but plenty of clunk for the rear
https://acurazine.com/forums/car-talk-5/04-supercharged-tl-150981/
Old May 11, 2007 | 10:27 AM
350TLS's Avatar
i got the same problems too..have u also try to slam on the brakes as u go over the speed bump? mine ABS brakes and slips and makes clunking sounds..try it..
Old May 11, 2007 | 11:25 AM
JCL622's Avatar
A-spec steering wheel ftw
350TLS - 1) you should not be slamming you brakes over any bumps
virafp - sounds like you may drive hard, and make some sharp turns, if it's what i think it is, it's happened to me before twice, where it's not a clunk but like a really weird clicking sound? coming from the front? if it is, take it to the dealer they'll replace it for you, if i remember correctly, a piece off the suspension up front is like torn/loose, and that is the sound you hear. Hope that helps
Old May 12, 2007 | 07:36 AM
350TLS's Avatar
a new car shouldnt have any brake problems..slam or not...
but..im gonna take the car to the dealer next week for them to replace the rear struts and have them look at the front again...this sucks...never thought i paid $37k for a new car and gotta have things fix...this is my first new car and i had better luck with used car..i know what route im gonna take now
Old May 13, 2007 | 11:11 AM
virafp's Avatar
driving habilts
Hi: The car is not driven at all hard. The speed bumps are on a street on my way home, and they are what's called "25 mph rated". Even at under 25 mph, the front clunks when coming off the speed bump. Also, this is going straight over the bumps, no turning at all.
The noise is more pronounced in the right front wheel.
Old May 13, 2007 | 12:31 PM
shooter's Avatar
Acuras Only in
that happened to me the first day when I took the car off the dealer's lot. Surprised the *&%# out of me ... never happened again & I saw some related topics about the clunks during break=in period, so I'd let it slip rather than take it back to the dealer. So far I've been babying the car, so we will see what happened after the 600 mark.
Old May 14, 2007 | 07:22 AM
350TLS's Avatar
let me ask you guys something...wouldn't you expect the car to be in perfect condition if you're spending $37k for a new car from a known company? also if something is wrong, doesnt it mean that something is not right and it needs a fix? this is my first new car and it would be my last..i had a choice between the type s and the is350..im beating myself right now..
Old May 20, 2007 | 12:20 AM
dtapia's Avatar
we have seen a few with front strut problems and acura is aware of it im pretty sure the current run has been corrected only seen a few in the first 07's but none since last year
Old May 21, 2007 | 08:13 AM
virafp's Avatar
April buy
My car was bought April 18th.
Old May 21, 2007 | 09:36 PM
dtapia's Avatar
wow should have been corrected or that car was in storage for some time before it was sold. any how their is a fix for it new struts.
Old Jun 30, 2007 | 05:11 PM
Gregzilla's Avatar
I had "the clunk" make an appearance at about 20 miles showing on the odo......took it back, they had the car for two days. It turned out to be the front stabilizer (sway bar) where it connects to the lower arm. The bolts, although tight, were not tightened to factory spec. Problem gone.....
Feb 25, 2020 09:57 AM
Heyzuez20
Oct 14, 2015 07:18 AM
milehightypes
Sep 10, 2015 12:07 PM
08 NBP TL
Sep 8, 2015 08:49 PM
Hau_nguyen91
Sep 6, 2015 12:53 PM
